I assumed that most know that the 80's don't have provisions for a elocker and that you had to grab the harness from the donor vehicle or make one haha! my apologies I will explain in more detail next time I post.
Not sure if you have purchased a head or not but i found this on KSL.
http://www.ksl.com/index.php?nid=218...=&search=alarm
Thought you may be interested.
A lot have been done today. Well a lot of work and a little progress. I've been cleaning nuts, bolts, and other random items. I also stated painting a few things. I got as far as putting the crank shaft and pistons in before called it quits for the day. When I installed the crankshaft and torqued it to 57 ft-lb it will rotate just fine. After installing the the pistons I just could no longer turn the crankshaft by hand I did not torque the rod cap bolts i just tightened them by hand. I have not used plastigage to measure the gap but I'll do that Monday.
I used Ford Red, Aluminum, and a flat black for paint. I don't like the flat black. I may repaint those parts a glossy black.
Found some very helpful videos on installing and testing some items on YouTube:
[YOUTUBE]http://www.youtube.com/watch?v=Ee9SC0K0nK8&list=UUav4NM5uSmA3VIuF6lw94iQ& index=2&feature=plcp[/YOUTUBE]
He has a few more helpful videos on his pages.
Just a thought, A locker is probably not gonna increase gas milage. A newer axle may also be a bit wider, which is not gonna help with MPG's either.
If you go to VIN.com you can put your vin into thier decoder and it will tell you what axle ratio you have, when the vehicle was made, just about anything you could want to know.
Tires will make a big diference. Smaller and skinnier will definitly increase MPG's
Quote:
You are correct and since my machine shop bill came in a little higher I've put off the elocker.Originally Posted by Slingin_rocks
Just a thought, A locker is probably not gonna increase gas milage. MPG's
I've torqued the rod cap nuts to 51 ft-lb. and everything is rotating smoothly. Tonight I'll be on page EM-74 of the FSM. I'll be cleaning and installing lots of nuts and bolts as I go.
I also placed an order from 22reperformance.com for: Belts Wires Fuel Filter PCV Hoses Thermostate Air Filter
Injector O-rings
I've made slow but steady progress tonight.
I've installed the timing chain dampers and tensioner. Do I hand tighten them or do i need to torque them to a specific ft - lb? I also noticed an off color link in the chain. is that significant? There is a dimple on the camshaft sprocket. I assume that is to help mark top dead center. Should that dimple face outward?
Does anyone have a part number for these three double treaded bolts on the cylinder head? I was able to get the ones off the other side but these won't budge so I'll just pick up new ones.
Can anyone identify these two sensors and where they go on the block? I think #1 is a knock sensor and #2 is a temperate sensor.
Found a nice write up for the timing chain:
http://www.4crawler.com/4x4/CheapTri...ingChain.shtml
For the sensors:
#1 is the knock sensor and is installed to the left of the oil filter
#2 is the oil pressure sensor and is installed just below the oil filter
For the sensors:
Damn that looks great. You are doing some good clean work. That runner will last forever. Great jo.
Thank I just finished painting the EFI and TOYOTA parts. They look super nice. I also adjusted my rockers. It going slow, about an hour or so a day. So far the hardest thing has been to find the right bolts. I didn't bag them as well as I thought.
Nice build thread, the red paint on the 22R-E looks great.
If you're in Utah, you should check out the North Utah Meet and Greet thread.
https://www.yotatech.com/forums/f15/...-greet-248902/
I'm getting close. If anyone is free Saturday I could use a hand to make sure I put this puzzle back together correctly.
I have not been able to find a gasket for this what does it look like?
This is the left engine mount. It doesn't seem to fit flush.
This is the right engine mount. It doesn't seem to fit flush.
Here is a few pics of the engine mounts off the 22re I just pulled out of my runner
On the left engine mount, it looks like you just need to take out the 2 bolts to your alternator bracket and put the left engine mount over the alternator bracket then reinsert the bolts:
here are a couple of the right engine mount... to me it looks like you are missing a little spacer between the engine block and the mount:
^^^ in this pic you can see the square spacer thats is a molded in part of the engine mount on the bottom bolt, it looks like you should have an additional spacer to match on the bolt hole above...I hope these pics help you out! Again nice work on your rebuild!
Quote:
If i new anything about engines, i'd come help you out. If you even need help lifting the thing in, let me know.Originally Posted by jaredbishop
