B-Rax 1988 4Runner build up thread
Old Nov 15, 2010 | 05:19 AM
B-Rax's Avatar
4Runner needs weather strip for the hard top sliding windows
I hope the title is specific enough. Heres the deal, i just bought an 88 4runner and am looking to restore then build it. ive been doing alrite replacing most of what needs to be replaced. one thing that i can not find on hte web is the weather stripping that goes around the sliding windows on the hard top. does anyone know a good website that will have these?
Also i want to put 33s on my truck and have seen multiple views on which lift i should use, i dont really want to do a suspension lift and was wondering what the best options are. and what else i would need to upgrade or modify.
Last edited by dropzone; Nov 19, 2010 at 03:13 AM. Reason: added your original thread title to this post
Old Nov 15, 2010 | 05:22 AM
B-Rax's Avatar
And if i can get away without any lift id rather do that
Old Nov 15, 2010 | 05:30 AM
waskillywabbit's Avatar
Buddy of mine went to a local auto glass shop and they had something that worked.
I have a nice 2" lift that would work nicely on your 4Runner
http://www.wabfab.org/IFS-Lift-Kits/...-products.html
:wabbit2:
Old Nov 15, 2010 | 05:40 AM
B-Rax's Avatar
thanks dude. sounds like a plan. will i have to regear?
Old Nov 15, 2010 | 06:40 AM
irab88's Avatar
32's are probably the biggest you want to go before re-gearing. for 33's, i'd go to 4:56 or 4:88
(i think i got that right?)
as for the wabbit lift, i'm planning on getting one next year. top quality stuff
Old Nov 15, 2010 | 06:49 AM
B-Rax's Avatar
Thanks Ian. im new to all this. does 1 inch make that big of a difference? Any way thanks for the help guys this truck has been a pain ever since i bought it. fake title, addict owner, fake plates on it, and got pulled over on the way home.... and in the great state of VA it could be 90 days in jail. find out on the 18th.
Old Nov 15, 2010 | 07:07 AM
irab88's Avatar
after cranking my torsion bars (search around for some of the terms), 1" of height made a big difference for me. check out page 3 of my build thread, where i installed add-a-leafs and tightened the torsion bars. best $100 spent (outside of the engine).
Old Nov 15, 2010 | 07:40 AM
Swimmerboy2112's Avatar
As far as lifts go, do BJ spacers up front and add-a-leafs in back. I fit my 33's doin that. As far as re-gearing goes. I have the stock 4.10 gears with the 22re (4cyl) engine and it does fine. I have 4.56 gears i'm going to throw in but you can get away with 4.10's on 33's.
Old Nov 15, 2010 | 07:41 AM
Also don't crank your torsion bars unless you want a really rough ride.
Old Nov 15, 2010 | 07:51 AM
B-Rax's Avatar
How much did that run you?
Old Nov 15, 2010 | 07:53 AM
B-Rax's Avatar
And as for the rust on my rig. It doesnt have any holes and nothing needs to be replaced. it just needs a new paint job. luckily the guy i bought it from was from Texas so it didnt rust too bad.
Old Nov 15, 2010 | 07:54 AM
The bj spacers, extended shocks, add-a-leafs and u-bolt flip kit cost me around $500 and i think i paid $200 for the 4.56 gears (both front and rears were $200 together). So a total of around $700
Old Nov 15, 2010 | 07:55 AM
irab88's Avatar
it's not that bad. i also have rs9000xl's, so that might have something to do with it
Old Nov 15, 2010 | 08:01 AM
Oh and you can get away with 33's and no lift, just gotta cut your fenders accordingly lol. IT CAN BE DONE!
Here's a pickup on 37's no lift
And a 4Runner on 37's no lift
Old Nov 15, 2010 | 08:32 AM
B-Rax's Avatar
Thats what i've been trying to figure out. there seems to be enough room around my 31"
tires now. which leads me to my next question did some of these things come with a body lift? mine has bushing between the body and frame and seems to sit higher then some i see on the roads.
And have you put up any photos with your 33s on yet
Old Nov 15, 2010 | 08:46 AM
No none came with body lifts but yours may have had one put on by the previous owner.
Here are some pics of mine on 33's i need to lift the back up another inch.
Rear
Side
Old Nov 15, 2010 | 08:51 AM
B-Rax's Avatar
um yeah im going to need to lift it. thanks i needed the perspective.
Old Nov 15, 2010 | 09:14 AM
Yep no problem. If you have any more questions shoot me a PM.
Old Nov 15, 2010 | 09:16 AM
B-Rax's Avatar
another question..... upon further inspection someone put a block under the leaf springs on top of the axle. the u bolts are after market. it looks like someone tryed to fix a sag problem. will this change my options?
and is that even safe?
Old Nov 15, 2010 | 09:17 AM
I'd pull that sucker out of there blocks suck. Any pics of the u-bolts? It may be a flip kit.
