93 v6 oil leak issues
Old Jul 23, 2017 | 09:41 AM
speedy gonzales's Avatar
so I bought this knowing it had an oil leak. yesterday I did the valve cover gaskets hoping that was the leak. It was not.
is there a bolt off the power steering pump and res brkts or the ac comp that requires rtv to seal the bolt? The leak seems to be right above the ac comp and it leaks quite a bit.
Any and all help is much appreciated.
Thnx
Jim
Old Jul 23, 2017 | 12:29 PM
ksti's Avatar
Instead of guessing, why don't you purchase a UV dye kit and narrow down where the leak or leaks are coming from.
Any auto parts store carries it. that way your not throwing money at something that doesn't need replacing.
Old Jul 23, 2017 | 01:03 PM
Great idea! I'll chk into that.
