91muddog's "Crystal" The 92 Pickup Mild offroad build!!
Old 11-18-2011, 12:02 AM
91muddog's Avatar
Josh, I would love more!!!
She got the CB and Scanner installed the other day, i still need a console to mount them too since they are just siting between the seats.
Uploaded with ImageShack.us
Old 11-18-2011, 02:45 AM
Staff
Terrys87's Avatar
That is great that you found the 2nd owner on here. Always nice to know the history on a truck.
Old 11-21-2011, 11:36 AM
toastyjosh's Avatar
Ok, No problem I will Let you know what I know.
The rear diff fill plug is rounded so will be a pain in the ass to get off, you will want to change fluid as well it was last done at about 220,000.
The damage in the front was a elk on one side deer on the other.
The is a idle issue which I am sure you know about. I will give you the background: The truck sat for about six weeks while I was in europe, the temps were down to -30 at times (gunnison, co) when I came back I hooked up the batt and she fired right up. I let it warm up for a while and came out of the house and I was doing the surge. I have tried everything to fix it so has my buddy I sold it to. I checked all vac lines, replaced temp sensor, timed it 10 times or more, you name it. Cleaned everything, new plugs,wires..... The only thing I never got to was to check the ECU grounds, or swap ecus with another 91 and see if that did it.
Also while checking other stuff I unpluged the brake switch under the dash and it stopped doing it.????
Good luck with it please let me know when you find it.
Old 11-21-2011, 03:50 PM
john4wd's Avatar
Great score for $400 bucks, And also great your redoing her, Not a topper fan anymore and it looks better without it, I really like the color you picked, I would like to do mine desert tan :}
Old 02-25-2012, 11:27 AM
  #25
toastyjosh's Avatar
Progress???
Old 01-03-2013, 11:15 AM
  #26
toastyjosh's Avatar
I know its been a while, but this should help with the idle.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
09-04-2015 09:27 AM
Avenged
07-09-2015 07:55 AM
toyoda8488
07-05-2015 10:18 PM
Quick Reply: 91muddog's "Crystal" The 92 Pickup Mild offroad build!!
