85gijunk4x4's 1988 pickup buildup thread (Angus)
I know you've got the seat back in but I lifted the carpet out when cleaning mine for the first time, hung it up and hit it with a pressure washer. It's amazing how clean it got and also how much crud was underneath it.
and i put toyota mudflaps on my floor since i dont have a set of floormates, so that way i can remove them and shake them off every now and then
yeahh i know whatcha mean...im slowly gettin to know the 3vz, but i just love the simpliticty of the 22re, it would be cool to have both my rigs the same engine so i can interchange parts and stuff like that to test out broken parts and whatever....but honestly i will probably talk about swapping a 22re, but never do it unless i have major engine complications, and it would be cheaper to swap a 22re rather then rebuild the 3vz
^^oh yah i know thats a pita!! i bet its 10x easier to have a second running truck you can swap parts on to find out whats broken, rather then running to the parts store 20x a day
#26
alright so heres the deal
havnt been updating this thread for a while, due to me being too tired after im done working to do anything else but sleep...but here we go, these are from 2-3 days ago...
pulled my truck into the garage, turned out the lights, and figured out qich ones worked and wich ones didnt ( i actually had to make a list...i thought i could keep track in my head, but there was so many lights i kept foegetting wich ones worked and wich ones didnt)
heres my list (the two lreverse lights i pulled out a few days ago...they pretty much rotted away)
well then after that, i pulled out the bulbs that didnt work, checked the fuses, and pulled out the meter....
it turns out theres no power to the light sockets
went to the back of the bed to trace the wires and found the culprit...now i have to re-wire the bed...wich is a MAJOR PITA
#27
in the meantime, i took care of my "click but no start problem" and put the light fiasco aside untull i pick up some new bulbs...thankfully my basic lights work (turn signals, brake lights, headlights, 4-ways) and its just the "accesory" lights that quit...
pulled off the wheel and tire to gain acess to the starter...
...told you my 3vze leaked like a sieve (thats supposed to by my starter)
so after i got that all taken care of i cut off the old bumper brackets, in hopes to bolt square steel tube to my frame and attach d-shackels as recovery/towing points
#28
so here comes the fun stuff!!
im sure you all remeber that infamous front valance...well if you dont here it is
i got around to trimming that the other day, but first i pulled off the corner bumber bracket things that were rubbing on the tire
(yeah these things^^...and any toyota enthusaist will notice the gastank skidplate off my 1985 on the trashcan in the background)
got the valance off...i kinda like the look of the truck without it on...
so anyway, got out some 2x4's to help bend the valance back into place
then after i got them kinda straight, i trimmed my valance...i was going to make templates to be sure it was even on both sides, but i kind of eye-balled it...it wouldnt be a true mesurment anyway because the valance was still alittle bent
here it is all trimmed...after that i sanded out all the rust spots, and scuffed the rest of it, getting it rady to paint (thats why its all "zebra-ish" looking in the pics)
put the valance back on...ehh, i didnt really like it...
after i shut the hood though, it was a whole different look
looks pretty good, PLUS the tires rub aloootttt less, and i can turn alot sharper!!!
#33
i kinda do like the look of the truck with the trimmed valance, im willing to run trimmed or no valance it doesnt matter to me, i just like the frame part with the holes to be covered up for now because mine is a little rusty...
but anyway, i got some new bulbs, im working on re-wiring some spots of the bed now to get my side lights and reverse lights to work...
i picked up some ammo cans and im probablygoing to mount them today in my bed to throw all my shackles and straps and snatch blocks etc. in there
#35
thanks chef! i think i might post this in the cheap mod thread when i get pics, the ammo cans were $10 ea. and they are in spectacular shape, i got 8 carrage bolts and washers for free from my buddy who works at the local hardware store (Thanks bill!) and filing square holes in the bottom and mounting the cans was free labor!! i had the locknuts laying around too so they count as free too, right?
today i got all kindsa bulbs and fuses, 2 rolls of electrical tape, and the lights i need for my bed from a buddy of mine who i farm with in the summer
i wired and spliced the new lights in thinking it could possibly be a ground problem since the light sockets were a little bit rusty, but they still didnt work so i guess i have to do a little re-wiring
#37
well awhile ago, the beggining of this month pretty much. i pulled off my shift boots, cleaned them up, and painted the little metal thing that holds them on, and cut off the trim brackets and made some rubber gap guards.
(sorry, no pics of the process )
i drove it around like this for a little bit, and kinda got sick of how ugly it looked. you can tell the guy spilled all kinds of stuff on it, because its rusty on that one side, and the way the carpet it stained.
you can see here the two brackets that held that stupid trim peice on, i got tired of them too so i cut them out. heres the finished product (pretty bad pics, i know)
