22repower 93 Single Cab 4x4
Old Dec 14, 2011 | 06:37 PM
22repower's Avatar
I started on the BJ spacers tonite got 3 out of 4 studs out on one side and disconnected the shock and sway bar
(stupid sway bar bolt broke ill deal with that later)
Old Dec 17, 2011 | 07:38 AM
22repower's Avatar
Spacers On:
Old Dec 17, 2011 | 03:21 PM
93Xtra-Cab's Avatar
Looks great! I'm thinking about getting some BJ spacers. What inch lift is yours? Also, in that pic do you have any lift on the back or is that just stock rear with the BJ'ed front? I think that stance is pretty menacing
Old Dec 17, 2011 | 03:56 PM
eggens's Avatar
Hey, 22RE, are you parting out that $300 rusty truck you picked up? PM me, I need a few parts, and would be happy to help a starving student out.....
Old Dec 17, 2011 | 04:00 PM
  #25
eggens's Avatar
Never mind, just saw it in your signature. Sent a PM.
Old Dec 19, 2011 | 04:16 PM
  #26
22repower's Avatar
It's got 1.5 in spacers, and you can't really tell from that crappy picture but front and rear are almost exactly the same
I ended up cutting the cherokee coils down to 12 in so I could fit them w/o a spring compressor, and that gave me the perfect height.
Get ready to hate those studs on the ball joints they are a nightmare, but I ended up finding a couple small sharp drill bits that saved the day
Old Dec 20, 2011 | 02:41 PM
  #27
22repower's Avatar
Fresh FA5040!!!
Went the autozone in canton a couple days ago and it wasn't in stock but the price was 35.99, so I went to one in Peoria that said they had it and it came up at 49.99!! a quick phone call took care of that...
Old Dec 21, 2011 | 07:55 PM
  #28
22repower's Avatar
Alignment tomorrow, no more suicide pull lol
(its not that bad but the bj's need one for sure)
And parts shipped to eggens
Old Jan 10, 2012 | 06:30 AM
  #29
22repower's Avatar
Put in a remanufactured alternator last night. I'm glad the plug was wired in for a 1990 alternator because the 93 that should've been there was almost 100 bucks more.
Old Jan 10, 2012 | 01:57 PM
  #30
possum34's Avatar
Good looking truck.I'm looking forward to see it progress.
On a side note, how you like them mud rovers?
Old Jan 11, 2012 | 10:54 AM
  #31
22repower's Avatar
I really like them for what they are,
They make some noise on the highway, but they dig great in dirt and mud
They are wearing kinda fast, but there all even and a ton better than the wildcats I had before
32 11.50 looks awesome, especially with the bj spacers, but with stocks 4.10s and a 4 banger they really hurt in the trails, 2nd gears bogs too easy in 4 lo on hills and 1st 4 high bogs in mud
Old Feb 8, 2012 | 08:30 PM
  #32
22repower's Avatar
I'm considering trying adjusting a spare afm i've got laying around a couple notches leaner to aim for some more mpg. It would be run with the stock air box/ paper filter and a free flowing exhaust.
What do you all think about it? I found a couple old threads split between whether it made a difference or not but none of them came to much of a conclusion. Also if I test it with a electrical tester to the terminals how would I want it to be different from the spec in the fsm?
Old Feb 14, 2012 | 04:26 AM
  #33
93Xtra-Cab's Avatar
Just a few questions about your Zuk mod in the rear because I'm planning one for my truck
Are the Cherokee coils big enough to fit over the top bumpstop?
Does it ride stiff?
Are they front or rear coils?
I was just wondering because if I can't find a set of TJ coils at the junkyard, I could always use XJ coils.
Old Feb 14, 2012 | 09:56 AM
  #34
22repower's Avatar
Does it ride stiff?
They fit over the bumpstop perfect
The ride did turn out pretty stiff, if I did it in the future I might try to find some coils with a lower spring rate but with those cut down to 12in I could get them in w/o a spring compressor and they matched perfect with the bj spacers on untouched torsion bar setting.
And they're front coils (xj's have leafs in the back)
Old Apr 17, 2012 | 06:06 PM
  #35
pac6's Avatar
with no cat is your truck a dog at low rpms? im in northern il with a reg cab 93 red no cat and its a total terd at low rpms
Old Apr 18, 2012 | 10:30 AM
  #36
22repower's Avatar
I can't really tell a difference from full exhaust, it seems to make a little more power in the higher rpm's but that about it. I know when I've drove it without the cherry bomb and second half of the pipe it'll run like crap.
Old Apr 18, 2012 | 10:33 AM
  #37
22repower's Avatar
Has anyone else with ball joint spacers had trouble keeping your alignment? My front ends way off a few months after I got it aligned the first time, and I haven't done much wheeling compared to what I've done in the past w/o the lift.
Old Apr 23, 2012 | 10:58 AM
  #38
22repower's Avatar
http://springfieldil.craigslist.org/cto/2939476284.html
Hopefully I can get this guy to trade it seems like a good deal if he will.
Old Apr 23, 2012 | 01:50 PM
  #39
93Xtra-Cab's Avatar
You would trade the single cab? I think you might miss the 5 speed.
Old Apr 24, 2012 | 08:01 AM
  #40
22repower's Avatar
I would but a solid axle 4runner would really be nice, and I have a good w56 laying around incase I really really want to make it a 5speed
