Sealant/RTV on Intake Manifold Gasket?
Old Mar 3, 2025 | 05:43 PM
squeege's Avatar
5 Year Member
I'm installing a lower intake manifold on a 22RE. I have an OEM gasket for between the lower manifold and head (part no. 17177-35022) and I'm wondering if I should use any kind of sealant or adhesive here. The shop manual just says to install it but I've noticed the later gaskets from Toyota for the 22RE have a rubber bead around the ports but this one is only fiber and seems a bit thin to me. I feel like that bead must have been added for a good reason.
Old Mar 30, 2025 | 09:13 AM
mechkw's Avatar
If you have the correct gasket no sealer is needed unless you think you need a LITTLE bit around the water ports b'cuz of minor pitting of the aluminum
squeege
Mar 7, 2025 06:36 AM
jdfnnl
Nov 6, 2024 07:18 PM
ehenson99
Mar 5, 2013 06:23 PM
YotaTheKid
Jul 19, 2009 09:46 AM
Boosted Chemist
Mar 23, 2005 07:37 PM
