broskyo's 1985 4Runner Build-Up Thread
Old 08-02-2009, 11:08 PM
broskyo's Avatar
Originally Posted by Rusty Boots
Looks great! Any plans for a paintjob?
I plan to do one eventually thats about it. haha
Old 08-02-2009, 11:16 PM
broskyo's Avatar
Originally Posted by desertcamper67
Looking good. How is your body roll in the rear? Is it squirrely on corners? Looks nice and flexy.
Its not to bad I'm happy with the way it feels. It can be a little squirrley at times but once everything is dialed in it should be better.
Old 04-29-2010, 01:23 PM
broskyo's Avatar
Haven't updated recently but I have made sliders, rear bumper, front diff armor and started on a front winch bumper...now time for some pics
Old 05-13-2010, 07:41 PM
broskyo's Avatar
Ok so the 4runner has been have trouble idling after its been run for about 30 seconds to a minute when its cold, and it wont idle at all when its warm. It also just starting bucking a couple days ago. I checked a the vacuum line they were all good so I check where then go into the throttle body and they were plugged with black gunk. After that I took the throttle body off and cleaned all the clogged parts and the rest, but there was a really thick layer of the black gunk in the whole body so I just made sure all the ports were cleared out and the put it all back together and now it wont run at all. If I can get it to start I have the keep the revs high or it will start backfiring or missing and die. I put all the vacuum lines back on and I'm almost positive there all in the right place.
So any ideas????
Old 05-15-2010, 08:15 AM
  #25
broskyo's Avatar
Angry
Any ideas??
Old 05-22-2010, 07:50 PM
  #26
broskyo's Avatar
The 4runner is still not running I've done the tps and afm tests on 4crawler. I was wondering if anyone knows if the AFM is supposed to make a loud ticking noise(like the air flow gate is opening and closing really fast) when the motor is cranking and almost firing up?
Old 05-31-2010, 09:43 AM
  #27
broskyo's Avatar
I just took my front axle apart to put my 5.29 third in and I got everything put back together but the axle inst sticking out enough to get the snap ring on.
Old 06-01-2010, 10:32 AM
  #28
85toy's Avatar
sometimes it gets pushed in a little bit, you should be able to pull it out enough to get the ring on, if you cant pull it out enough then you put it back together wrong.
06-01-2021 01:51 PM
icentropy
09-16-2020 02:47 PM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
jon.r
07-11-2015 03:34 PM
bryan34w
07-06-2015 05:53 PM
Quick Reply: broskyo's 1985 4Runner Build-Up Thread
