PWRstroke_smoke 1982 4x4 Pickup Build-Up Thread
#25
I thought about using peel and seal but wasn't sure if I wanted to stick tar back down. The carpet I'm putting back in is twice as thick as stock. I may still do the peel and seal I'm not sure yet.
Does everyone seem to like it?
#31
It always helps when someone knows what they are doing. I've had 2 replaced due to damage beyond repair and haven't had a problem with leaks. Working on taking mine out during my build and will do the same as you. It's one of the "smart" moves on these things.
#34
Tire gate and bumper I built with my uncle
6" icon lift
2010 f150 platinum seat
Gtp38r
Stage ones
35's on bmf sota's
Sb intake
Mbrp turbo back exhaust
Tony wildman tuned chip
#35
Go these today at home depot for the rear sliding window. The latch is missing on my rear slider, thought these would do great for now. I was going to make something with all thread rod then i found these.
Ill probably still continue to use them even after i get a new latch. I put two on either side on the bottom, 4 come in a pack so you could even do 2 at the top also.
They just slide in the rear window channel and tighten down. After you get them where you want them you can even drill a little hole in the side of the window channel for the set screw to go through.
#39
got some wheel spacers and new tires for the original wheels. They are toyo mt's 33 10.50 r15
I inspected the brakes while the wheels were off and the pads still were good but the rotors are rough condition and grooved, so i will be replacing those soon
