83crawler's 1983 Pickup Build-Up Thread
Old Jan 5, 2012 | 10:36 AM
  #41
83crawler's Avatar
well once i start working again im going to get all this stuff done
1.30spline longs, with hub gears full marlin crawler rebuild, arp knuckle studs and arp hub studs ifs hub with fj60 rotors and v6 calipers
2. new 529s detriot up front and spool in back
3.duals with mc07 adapter and chromo 4.7s with long field output with front range off road crossmember, get some driveline tech drives front and rear, w56 and marlincrawler 1600 pound clutch
4put on my ifs rear axle with disk brakes
5. 2nd gen rears up front mixed with 2wd rears and boomerang shackles 63s in back with frenched spring hanger and shackle on back of the frame
6. 4xinnovations interior cage
7.get my motor rebuilt.
8.40in mtr with 17in dimond racing wheels with 2 or 2.5 backspace
9. 2nd gen 4runner buck seats
10. fix my heater clean up all the wiring only get the wires i need.
11. put stereo in and some speakers and hopefully a sub
12. fix rust hole in the floor.
and thats it for now! i hope
Old Jan 5, 2012 | 10:46 AM
  #42
irab88's Avatar
sweet!
mind taking pictures of the engine (inside/outside) when you re-build it?
Old Jan 5, 2012 | 10:54 AM
  #43
83crawler's Avatar
ya i will i wanna put the msd ignition so i can have a rev limiter and a little hotter spark for the propane,
Old Jan 5, 2012 | 10:58 AM
  #44
irab88's Avatar
have you done anything with the ignition timing since you got 'pane?
Old Jan 5, 2012 | 11:54 AM
  #45
creswellhick's Avatar
nice truck again always nice to see a nice wheeler in oregon
Old Jan 5, 2012 | 12:11 PM
  #46
1981yoda's Avatar
Originally Posted by 83crawler
your truck is sick to! gotta love the army green,
Thanks! it runs and drives good, but needs lots of little work. gotta service the axles build bumpers and such. only thing i've done to it, got the tires and wheels and put a spartan locker in the rear couple weeks ago. plan to dd it someday lol. wish you were closer, so we could wheel
Old Jan 5, 2012 | 12:58 PM
  #47
83crawler's Avatar
i have not, but i will once engine is done,
and where you do you live at 81?
Old Jan 5, 2012 | 03:40 PM
  #48
1981yoda's Avatar
all the way in south carolina! only got one place to legally wheel thats about 30 minutes from me, a place called Gulches. its ok. its only like 82 acres of short trails but its always fun to go
Old Jan 7, 2012 | 09:32 PM
  #49
ThomasByota's Avatar
83 crawler you said you live in milwaukie? I am picking up a 79 on monday and i live in milwaukie oregon, maybe sometime after i get situated in my truck we could go wheeling after yours is done?
Old Jan 9, 2012 | 08:00 AM
  #50
83crawler's Avatar
o you buy that blue truck thats in your pic? and yes i live in milwaukie where yuou live?
Old Jan 19, 2012 | 04:43 PM
  #51
83crawler's Avatar
so im pretty sure im going to do a 3rz swap, i cant wait to yard out the old 22r and propane and put a 3rz way better power
Old Jan 19, 2012 | 05:41 PM
  #52
irab88's Avatar
you know, they sell propane injection kits that'll work with the 3rz... if you wanted to keep the 'pane
Old Jan 19, 2012 | 06:43 PM
  #53
83crawler's Avatar
really? i havent found one, send me a link
Old Jan 19, 2012 | 06:57 PM
  #54
irab88's Avatar
http://www.ebay.com/itm/4-cylinders-...#ht_2682wt_840
http://www.ebay.com/itm/LPG-GPL-auto...4#ht_879wt_700
http://www.ebay.com/itm/DUAL-FUEL-PR...#ht_1201wt_700
i'll dig out more info later. one of the vendors (the first one, i think) gave me the installation instructions. basically the same setup as now, but instead of the intake adapter, there's a series of injectors that feed the intake plenum
they've actually come down in price a whole bunch
Old Jan 20, 2012 | 07:28 AM
  #55
83crawler's Avatar
thats cool i had no idea there was something out there like that
Old Jan 20, 2012 | 07:30 AM
  #56
irab88's Avatar
once i get a better income (aka a job) i'd like to do either this or a diesel swap (or get another truck and do both)
edit- here's the email chain with a bunch of info on the kit:
Hi Ian,
the converter temperature sensor is fitted to the LPg pressure reducer.
The vapour sensor is mounted on teh injector rail.
The multivalve is the valve block fitted to the tank. This includes the level float, filler entry, filling stop valve and outlet valve with electronic shut off.
The cut intector wiring will be for 4 cylinders only. Bosch fittings are offered as an extra but you will want the solder in ones that come as standard. That makes the job neater and Jap plugs vary and often do not fit. I very rarly use plug in looms.
The UK filler system uses the bayonet system. I'm sure the US normaly uses the ACME system - I can supply an ACME filler as they are also used in parts of Europe.
Do you want some photo's showing the layout of the system?
Regards
Dai
To: dai@classicswede.com
Sent: Wednesday, 9 March, 2011 14:37:08 GMT +00:00 GMT Britain, Ireland, Portugal
Subject: Re: LPG conversion kit
Thanks Dai,
Those helped. Just a few questions about the diagram on page 17-33:
-Where is the "converter temperature sensor"?
-Connections 6 and 7 are left disconnected, but I'm assuming they can be connected for read-out information on a PC? How/where would they connect?
-Where is the "multivalve"?
-For the "cut injector wiring", does the kit come with it for 4 cylinder engines? And what style termination connector does it have for the injectors?
-Are UK and US propane fittings the same? Or do I need an adapter? I'm not too familiar with other propane systems.
Sorry for all the questions, but I want to make an informed decision. So far, I'm understanding this system much more than before.
--Ian
Subject: LPG conversion kit
To: irab88@yahoo.com
Date: Wednesday, March 9, 2011, 6:50 AM
Hi Ian,
the tank system is slightly differnt for the USA so you realy only need to look at the front end instructions. The hardest part is the wiring.
Enclosed are the wiring diagrams.
Regards
Dai
Old Jan 20, 2012 | 07:49 AM
  #57
irab88's Avatar
and here's a link to the attachments of the instruction manual:
http://s1179.photobucket.com/albums/...e%20Injection/
Old Jan 25, 2012 | 08:43 PM
  #58
83crawler's Avatar
So I'm pretty sure I'm selling cause I wanna build A 84 to 89 4runner hopefully I can get good money out of it
Old Mar 13, 2012 | 06:40 PM
  #59
83crawler's Avatar
well keeping truck and im buying a 97 3rz this saturday to swap in
Old Mar 14, 2012 | 05:06 AM
  #60
irab88's Avatar
sweet. don't forget pics!!!
(and a link to the new thread, if you're starting one)
