Vehicles - Parting Out Parting out a vehicle, post it here
FS[PacSouthWest]: 89 V6 4RUNNER A/T NO BODY & 87 4runner rollover
Old Mar 24, 2014 | 09:43 PM
ChefYota4x4's Avatar
Originally Posted by twistedyota
Heyy chef do you have the clip that holds the plug onto the tps(22re)?
I might have already answered you, and if so I'm sorry. Lol. I've just been so slammed! I do not have that clip, I only have one of the clips to what is I believe either the coolant temperature sensor or the cold start injector time switch. I sold both connectors that I had with the wiring and all that, and both with clips. Sorry Bubba!
Originally Posted by msalata
Hey there, I'm in need of the tailgate latch cables. If you have em let me know how much shipped to 94611. Thanks a bunch!
I just sold my last pair the other day. I will likely be removing one of the pairs that I have from the donor vehicle or mine, but I just haven't had time lately.
Originally Posted by blacktail hunter
Looking for the passenger steering knuckle, if you have one available and are willing to ship to the bay area (94565).
I guess I definitely will once I pull some parts off of the donor vehicle. I do have complete knuckles spindle and hub and slotted and drilled 11.75" black zink rotors and totally refurbished manual locking hubs, call complete still from my truck before I went SAS...... But I don't want to break it up. I will post a thread once I have everything broken down
Old Mar 26, 2014 | 06:37 PM
lfdy's Avatar
whats the transfer case from chef??
Old Mar 26, 2014 | 08:33 PM
89 V6 Auto
Old Apr 11, 2014 | 02:17 PM
clok's Avatar
Just checking if you got a drivers side power mirror laying around ?
Old Apr 12, 2014 | 08:46 AM
  #25
I don't man. ....
I'm going to reinstall mine, and these on this are manual. On top of that, the passenger one that I had a spare of before my rollover was and is mint. The driver side power mirror that I found at the yard with a buddy, its very tight and in great condition except it has no glass. So I will have to find some glass that will fit. I am surprised how hard to find these are becoming.
Old Apr 19, 2014 | 02:27 PM
  #26
Inferno451's Avatar
Do you still have the interior door pulls and exterior door handles? Looking for grey door panels and preferable chrome outside handles, but black is ok too. Also looking for the "4Runner" badges behind the doors. Located at 83404.
Old Apr 24, 2014 | 08:18 PM
  #27
Sorry I just saw this man. I will have out or chrome handles but likely not on the door pulls, and less a buddy of mine decides not to take them. I will shoot you a message
Old Apr 24, 2014 | 08:49 PM
  #28
CAdot's Avatar
Old Apr 27, 2014 | 10:29 PM
  #29
Originally Posted by CAdot
Hey you think gas filler neck tube and drain plug will fit onto my 80'? Willing to sell those bits?
So sorry, just saw this....
Not sure if they will fit buddy. If you mean the drain plug from the fuel tank, I don't want to separate that from the tank. As far as the neck tube, are you talking about the rubber neck that fuel makes contact with?
Old Apr 28, 2014 | 12:16 AM
  #30
EDIT!!! Updated the initial post. PARTS LIST. Bump!
Old Apr 28, 2014 | 10:47 AM
  #31
Bump! Adding pics today
Old Apr 29, 2014 | 02:17 PM
  #32
Bump, and TTT, adding pics today cuz Photobucket froze on me yesterday
Old Apr 30, 2014 | 12:16 AM
  #33
Dang I have the most problems with the apps I use most. 2 days I've had problems with Photobucket! Grrrr
Old Apr 30, 2014 | 11:29 PM
  #34
Texastaco's Avatar
Would you have complete ac unit for 1989 toyota pickup. Zip code 78553
Old May 5, 2014 | 07:01 PM
  #35
KYStumbler's Avatar
Hey, I wanted to see if you had any B-pillar interior pieces in in the beige/brown color? It's the piece that the seatbelt comes out of. I'm looking for both sides. If you have any other brown/beige interior trim, I'd love to take it off your hands. I'm near DC, so I understand if it's a hassle to ship out my way. Thanks for all your hard work!
Old May 6, 2014 | 10:32 AM
  #36
Hey man, what I have is basically A 87 4 runner evap box/89 V6 4runner AC lines/ 89 v6 4 runner condenser with dryer lines and everything, dryer still attached( the dryer set up and AC lines looked exactly the same as my 87 4runner).../ and I believe the Denso compressor that I grabbed at the yard was from an 87 4runner the clutch tested perfectly fine on. My evap box and condenser and everything was working perfectly, I had fully charged it with R12. I also have a mint condition blower motor and climate control assembly and the blower motor has a brand new 4 setting resistor and the climate control assembly has the for settings fan switch. I believe it should all work in your application. The only problem is when I rolled, the door jamb pillar on the passenger side pushed on the entire dash and a little tab on the bottom of the evap box broke( it didn't messed up the evap core- mini condense at all, it just pushed on the bottom right corner and made a little crack ) I believe it would still mount securely as it was so tight in there, even after I removed the heater core box, but you would have to check and I would gladly give you a good deal on all of it. Let me know if you're interested. I also have the AC and blower climate control relay module box that has the fuses and two relays, but you probably already have that in your pick up and just need the relay.
Sorry buddy, I don't have any brown. Thanks for checking in though. And as far as all my hard work, thanks, lol. I don't know what else to do, because I lose my mind if I'm not fixing or building something. Haha
Old May 26, 2014 | 04:12 PM
  #37
westjohns yota's Avatar
mark! how ya been man??, I need driver side kick panel in gray? what about the cover goes at the bottom of the door frame that runs from bottom of kick panel to rear passenger area? and maybe gray console lid?
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
icentropy
Sep 16, 2020 02:47 PM
Sep 4, 2015 09:27 AM
skoti89
Jul 6, 2015 07:45 PM
