Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
Question about the area under the intake manifold in a Chevy v8
Old Jul 24, 2011 | 05:46 PM
jener8tionx's Avatar
I have a 1994 Chevy C1500 V8 5.7L. I replaced the intake manifold gaskets today and I am unsure about what the area under the manifold is doing under normal operation. There are valve rods in there, but not much more.
When the engine is running, does this area fill with oil or does some oil circulate in this space?
I had some coolant in there, I assume from the leaking intake manifold gasket. Does that sound right?
Thanks for the help.
Old Jul 25, 2011 | 06:57 AM
swampfox's Avatar
The coolant is probley from the intake when it was removed. I usually pull the drain plug and let the contaminated oil to drain as the work is going on. Put in new oil and filter and get it to operating temp drain and change both again. and yes there is oil circulating under there.
Old Jul 25, 2011 | 07:39 PM
Thank you for the reply.
tj884Rdlx
Aug 28, 2015 12:04 PM
whereAreMyPants
Jul 22, 2015 03:32 AM
rushw
Jul 18, 2015 01:46 PM
87blyota
Jul 10, 2015 04:31 AM
wilbertd
Jul 6, 2015 07:39 AM
