Other Makes Cars/Trucks Own a different car or truck other than a Toyota?
My 1993 Mazda Rx7
Old Feb 28, 2011 | 09:00 PM
Frumundajs7's Avatar
My 1993 Mazda Rx7
I have had this car for about 7 years now and it has come along way! It is currently stripped down to the chassis for paint, so it will be a while before it is back on the road!
2002 F body ls1
ls6 intake
ls6 heads
232/237 590/590 112lsa comp cam
JRT 1 3/4" longtubes
Comp push rods
Comp 918 valve springs
Harris Speedworks nitrous plate kit
Hinson Supercars Front subframe, radiator, 3.5" CIA, bump steer tie rod ends, torque arm
Wilwood 1 7/8 clutch master cylinder
Spec 3 clutch
Tokico 5 way ajustable struts
Eibach springs
rx7store.com delrin differential bushings, cnc toe links, cnc trailing arms
JDM turbo 2 clutch-style differential
3:90 rear gear
Recent engine bay pic before I pulled it out again.
How it looks now.
Pretty sad I can't drive it, but it was old and busted, and needed a fresh look!
Old Mar 3, 2011 | 04:00 PM
hub_01_69's Avatar
Very Nice! I have one of these as well. Absolute blast to drive!
Old Mar 8, 2011 | 07:33 AM
tlrskunk's Avatar
Are you planning to shave the engine bay before paint? It will look super clean and it isn't to hard to do. time consuming but not hard.
Old Mar 8, 2011 | 07:58 AM
Drunner's Avatar
Nice FD I used to race a FC and have to say that I am a HUGE fan of the rotary motor and am a little disapointed to see a chevy in your ride but bet it will look good when your done
Old Mar 13, 2011 | 08:34 PM
laskt9's Avatar
same here. i have had a couple fcs and an fd. shame on you for using a chevy motor.
Old Mar 29, 2011 | 06:54 PM
Yes I am shaving the bay, I am about half way through the painful process. The rotary motor had 22k on it before it let go of a seal. This Chevy motor makes 580whp on pump gas and weighs 80lbs less than the rotary while yielding a better front to rear weight distribution over stock. Not to mention that weighing in at 2675lbs it gets 28 highway MPG with the t56 and 3:90 rear gear. I sometimes miss the rotary but this engine is way more practical for what I am trying to achieve. Thanks for the compliments gentlemen.
ladybugRC
458
Aug 21, 2020 10:41 AM
smilen724
13
Nov 8, 2015 04:11 PM
Ditch Doc
Oct 27, 2015 03:20 PM
kcaudill
Oct 10, 2015 02:39 PM
ToyotaMD
Sep 22, 2015 04:49 AM
