WTT: My OE '94 4.88 gears for your 4.10s
EDIT: Already found a local guy to swap. Please delete.
You read that right, I want rid of my 4.88s and to install 4.10s. Parts located in Houston, TX, I do not want to ship. I would consider driving to Austin, Dallas, SA.. as long as you split fuel. This will be cheap as my other car is a Diesel VW (~45mpg)
I just bought a 94 4runner that came with 4.88s. v6 rear, ADD IFS front, 156K miles, no problems except a leaky rear pinion seal. I want 4.10s to get the cruising rpms down for my diesel swap. Someone in town must recognize the value of these over some dime-a-dozen 4.10s, I just need to find that person.
what I want:
OEM 4.10 v6 rear third member, 4.10 front NON-ADD IFS differential
what you'll get:
OEM 4.88 v6 rear third member, 4.88 front ADD IFS differential & actuator
if 18 people start fighting over these, things I need that will sweeten the deal are a 2nd gen 4runner tool kit, jack, & spare tire crank rod, IFS locking hubs... thats about all I need, unless one of you has a spare 1KZ-TE bellhousing, flywheel & clutch setup.. JDM 1KZ-TE automatic shifter... Didn't think so.
This is posted on TTORA and a local club board also in an attempt to get a local trade quickly. However, once I tell you they are yours, I stand behind that.
Thanks,
Justin
what I want:
what you'll get:
Thanks,
Justin
XtraCab
Apr 12, 2020 05:25 AM
FS[PacNorWest]: 1992 4runner - 5VZ swap - Lifted
Swim
9
Jan 4, 2016 10:47 AM
jerusry
Oct 19, 2015 05:28 PM
