TRD e-locker rear axle
TRD rear axle (e locker version for those who dont know) from an 02 tacoma if i remember right. has about 20k on it. Low pinion 8'' third with 4.10 gears, never been taken apart. still have the short wiring harness that goes from axle to frame on the tacos. $750 OBO located in northern ut. buyer pays shipping
it will work fine, you have to do the usual mods to your diff housing and make a wiring harness... there are several GOOD writeups on how to do all this. I just put one in mine from an 08 Taco, and having an ELocker in your trail truck is well worth the trouble. Make sure its the ratio you want though, if you have to re-gear, it will ad a lot of extra cost, and you might as well just get a new one with the correct gear ratio for your needs...
right now im not sellling third by itself, but to put the whole axle under your truck, you'd have to weld on coil bckets, tabs etc....
FS[GreatLakes]: Toyota collection part out
88sasturbotoy
Jan 30, 2026 01:57 PM
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
toyoda8488
Jul 5, 2015 10:18 PM
