PARTING OUT - 1990, 1995, 1997 4RUNNERS and 1988 FJ62
#122
Does the 90 or 95 have front mud flaps with mounts compatible with a pickup (no running boards)?
#125
Hi, I'm looking for a stock oem pop up sunroof that'll fit a 91' ext cab - thanks...
#126
#128
Hows the console shifter indicator lens on the 97? Mine is cracked. How much shipped to 77373? You wouldn't have a fog light cover blank on the 97?
#130
Looking for this piece from one of your 2nd Gens, if in good condition how much shipped to 98801?
#131
#133
Hey I am looking for the gas fill door off of your '90 4runner. Hopefully the locking tab is still intact.. let me know.
#134
hey what gearing you got in that 4runner? there should be a sticker in the door jam in the bottom right corner look for the code should start with a G. I'm interested in the front and rear diffs
#135
#136
WOW - guess I need to check yotatech more. I just now got an email saying I had new responses.
No sure what you mean. Sunroof is moved by a motor?
Not sure what that is
No a good one.
I have that. $30 shipped.
Yes.
Not sure I have one of those.
I have a brown one. $30 shipped.
I think 4.10. It from a 5 speed.
Got a couple. Email me your info for a shipping quote. yesgeek[at]gmail.com - replace [at] w/ @
No a good one.
Yes.
#137
Edit: on the 95, shipped to 60563
I kind of assume shipping will be crazy to me for anything but there are a few things I'd be interested in. First off, can you send pics of the interior? I could use the carpet if it's not trashed and the dash if it's not either. Also the sunroof shade handle.
And now the I assume not question but have to ask. Is the body rusty? If not, would you be willing to cut it up after everything else is gone?
#138
#139
Wanted exhaust heat shield 1993 3VZE see photo
Looking for an Exhaust Heat Shield for 1993 Pickup 3VZE 3.0L. This shield is bolted to the frame on drivers side. It is between exhaust manifold and control arm. It measures about 12 inches across and has 3 mounting holes.
