Parting out 01 4Runner (AT,4x4,SR5,78K) - Norhern Colorado
Old Jan 13, 2013 | 09:21 AM
mussy01's Avatar
Parting out 01 4Runner (AT,4x4,SR5,78K) - Northern Colorado
*******ITEM LIST BELOW UPDATED AS OF 7-23-2013. Went through my items completely and these are the only things I have left. If it's not on the list I do not have it. If you'd like pics of anything just let me know and I'll post or PM them ********
Hi all,
I am located in the Fort Collins, CO area and am beginning to part out a 2001 4Runner that I purchased for a 3.4L swap. A bit of background on the vehicle to start. It was a SR5 model with an auto tranny, 4x4, and 78K on the odometer before it was in a rollover that damaged the driver’s side body and bent the rear axle. I picked it up in Kansas City and towed it to CO, but the vehicle started just fine and I was able to drive it into the garage despite the bent rear axle. At this stage in the game the vehicle has been completed stripped and the carcass has been sent to the junkyard.
[font=Times New Roman]
The following list is what I have available as of today. I will use this first post to update when items have been sold. The prices listed do not include shipping so please include a zip code in your PM for items you’re interested in. I will not ship items like the AT, doors, or sunroof. I will accept paypal, cash, or bank checks, and once payment is received I will quickly get the items shipped. Prices are negotiable so feel free to let me know what you’re interested in and we’ll go from there. I also have a few items from a 93’ 4Runner w/ 3.0 if you’re interested.
Pics can be found here: (link to the top folder; drill down to sub-folders on the left of the page)
http://s1285.beta.photobucket.com/us...yota%204Runner
- Rear Upper Control Arms - $20
- Rear Stabilizer Bar - $20
- Rear Lateral Control Rod - $20
- Front Brake Calipers $20
- Radiator $50
- Coolant overflow resevoir $15
- AC Condensor $40
- Fan $30
- Fan clutch $25
- Fan Shroud $20
- Hood Hinges (2) $10
- Auto Transmission & T-case $750
- Lower Transmission Inspcection Cover - $15
- Transmission Cooler $40
- Transmission & 4WD Shifter Assy SOLD
- Front Driveshaft $40
- Rear Driveshaft $60
- Rear Passenger Door (100%) $150
- Front Passenger Door (100%) $150
- Front Driver Door window (main) $50
- Front Driver Door window (pocket) $40
- Rear Driver Door window (main) $50
- Driver door (front & rear) internals (let me know what you're looking for)
- Front Passenger Fender w/o Flare $100
- Front Passenger Fender Flare SOLD
- Rear Passenger Qtr Panel Flare $40
- Sunroof Glass $100
- Spare Tire/wheel (Bridgestone Dueller H/T 31x70Rx16) $30
- Gas Tank Door and cap $20
- Front wiper arms and blade $20
- Rear wiper arm and blade $15
- Heater Unit (including heater core) $40
- Cooling Unit $40
- Rear heater unit $40
- ABS / TRS / VSC computer (89540-35270) SOLD
- Glove Box Airbag $100
- Stereo Amp Assembly (86280-35080) $35
- Running Light Relay Assembly $15
- Antenna Relay (85914-35010) $30
- 4WD Computer Control (89533-35170) $45
- Airbag Sensor Assembly (89170-35120) $75
- Hood Latch and cable $15
- Hood lactch assy (underhood) $15
- Gas Cap Door Latch and cable $15
- E-brake cable only - $15
- Steering Wheel pad with airbag $100
- Steering Combination Switch (lights) - $25
- Steering universal join $15
- Steering Column Hole Cover (2 different) $10
- Starter Switch Bezel $10
- Cluster Finish Panel $20
- Assist Grips SOLD
- AC Compressor $75
- Relay (90987-02012) - 6 qty $10/ea
- Running light relay (82642-35010) - 1 qty $25
- Rear wiper motor assy (85130-35070) $45
- Front wiper motor assy (85110-35280) $45
- ECU-5VZ,AT,4x4 (89666-35420) $100
- ECU-5VZ,MT,4x4 (89666-35131) $150
- Dash knockout cover trim - Qty 4 $10/ea
- Tailgate wiring harness $50
- Tow hooks Qty 2 $20 both
- Dimmer relay (85926-30020) $10
- Hazard light switch $15
- Relay (90987-02006) $5
- Turn Flasher Assy (81980-32010) $15
- Relay assy running light (82810-04011) $40
- Sensor assy Yaw rate (89180-35010) $60
- Brake pedal assembly $30
- Gas pedal assembly $30
- ADD actuator SOLD
- Rear spoiler light $15
- Fuel filler down tube $20
- Fuel tank with pump $150
- Complete Engine harness $125
- Engine Mounts - $30
- HP power steering line - $40
- Horns (86520-60160 / 85610-60190) $10/ea
- Auto tranny lower inspection plate $10
- Buzzer assy (89747-35010) $25
- Front diff skid plate $25
- Fuel tank skid plate $40
[/COLOR]
Old Jan 14, 2013 | 01:16 AM
toYAUta's Avatar
I'm looking for the ecu that is in the rear hatch that controls the window and wiper and also the gauge cluster shipped to 60526
Old Jan 14, 2013 | 05:56 AM
mussy01's Avatar
Just to confirm the item # you're looking for is 123300-6410? If so, I do have that as well as the rest of the mechnicals out of the rear hatch in case you need anything else.
For both those items I would do $70 shipped. Just let me know if that works for you.
Thank you,
Eric
Old Jan 15, 2013 | 06:22 PM
mussy01's Avatar
Post #1 updated for a few sold items.
Thank you,
Eric
Old Jan 17, 2013 | 09:12 PM
T-DUB907's Avatar
part out
how much to ship center consol and park brake handle to anchorage, Alaska?
Old Jan 18, 2013 | 05:10 AM
mussy01's Avatar
Hello,
I have agreed to a price with someone on the rear foldable cupholders on the center console and am waiting payment. With that being the case, are you still interested in the center console?
If you can confirm you'd still like the console, I'll PM you a price for both items including shipping.
Thank you,
Eric
Old Jan 23, 2013 | 12:09 AM
toYAUta's Avatar
Bump for a great seller!!!
Received my parts today.
-Great condition
-Fast shipping
-Very quick overall transaction
Thanks again Eric
Scott
Old Jan 23, 2013 | 05:48 PM
hrt4me's Avatar
can you please send me pics of the Center Console (w/o rear cupholder), both sun visors and the overhead console (if you have it)///
Old Jan 23, 2013 | 06:06 PM
mussy01's Avatar
PM Sent.
Thank you!
Eric
Old Jan 23, 2013 | 09:45 PM
mussy01's Avatar
Will part out driver side doors
If anyone is interested in any components off of the front or rear driver's side doors just let me know as I am willing to part them out. I have sold the power switch assemblies for the front door.
Still looking to keep the passenger side doors 100% complete as they didn't have any damage to them.
Here are a couple specific pics of the driver side doors:
Old Jan 30, 2013 | 04:54 PM
mussy01's Avatar
Bumpity
Old Jan 31, 2013 | 06:37 AM
vikingsven's Avatar
How do you want for the ash tray shipped to 95492?
Old Jan 31, 2013 | 07:30 AM
mussy01's Avatar
How does $18 shipped work for you? If that works shoot me a PM and I'll get you my Paypal address and you can provide your shipping details.
Thank you,
Eric
Old Jan 31, 2013 | 07:12 PM
mattp1492's Avatar
Great to do business with
Eric has a bunch of clean items at a fair price. He sends high quality pictures of what you want to buy and shipping was quick and well organized. Definitely a great seller, very pleased!
Thanks Eric!
Old Feb 8, 2013 | 08:59 AM
AZ4ME's Avatar
Got the part. Great prices. Thanks.
Old Feb 9, 2013 | 11:48 AM
Citykid's Avatar
Don't have seats available do you?
Old Feb 9, 2013 | 01:21 PM
mussy01's Avatar
The seats are indeed gone. One of the first things to go.
Thanks for your interest.
Eric
Old Feb 19, 2013 | 04:42 PM
bSkogie's Avatar
Do you have the front differential? What gear ratio?
Old Feb 19, 2013 | 06:02 PM
mussy01's Avatar
Unfortunately the front and rear diff's both went to the salvage yard with the body.
Thank you for your interest.
Old Feb 22, 2013 | 04:14 PM
Inthepipe5by5's Avatar
Do you still have the rake master cylinder assembly? Can I get a photo and quote for shipping to 96932 via USPS priority?
