FS: Fabtech Ivan Dan 6" 84-88 (89-95?) 2wd lift kit
Old Aug 16, 2008 | 08:32 PM
JamesD's Avatar
Exclamation FS: Fabtech Ivan Dan 6" 84-88 (89-95?) 2wd lift kit
I bought this kit 11 years ago for $2600. I'm selling just the front kit. I do not have the rear kit but what I bought was the add-a-leaf and longer shackles. I recommend new springs and shackles rather than the add-a-leaf.
This kit is not exactly a bolt on, welding is required. What you see is what you get. I do have the instructions still and it will be provided but they are not the greatest set of instructions. This is for the dual shock setup. It will work on the 89-95 if you fabricated some bolt holes in the front. The strut frame bolts to the bumper bracket holes and as you know the 89-95 trucks are on the side of the frame but other than that, that is the only difference. It weighs roughly 85 lbs total.
As for the rust, it is just surface rust and none of the parts are rotted out. Fabtech powder coated them instead of painting them and I believe that is what saved them from rotting out. You all know they do not make this kit anymore. This kit is better than the lift spindles since this kit will give you more suspension travel. Have any questions just ask and I will try to answer them the best I can.
Asking $600+shipping
James
Old Aug 17, 2008 | 06:48 PM
JamesD's Avatar
Ttt............
Old Aug 28, 2008 | 05:00 PM
JamesD's Avatar
sold!
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
kirkrunner
Jul 27, 2015 07:59 PM
justdifferentials
Just Differentials
Jul 22, 2015 08:26 PM
