FS: 22RE Master Rebuild Kit HIGH QUALITY
Hey Toyota Brothers!!!
I've got a complete master rebuild kit from Hi-Tech Engin components. I'm moving and need to lighten my load. Here are the details:
It fits a 85 to 95 22RE application.
The pistons and rings are both 1mm over
Cam:
Cam Int: 0.262
Lift Exh: 0.264
Valve Int: 0.380
Lift Exh: 0.382
Lash Int: 0.00
Hot Exh: 0.01
Kit includes:
Full gasket kit
Oil Pump
Lifters
Pistons
Rings
Cam
Main Bearings (.010 over)
Cam Bearings
Rockers
Block Plugs
Timing Set
Heres some info I found about Hi-Tech:
To estimate shipping cost:
Total Weight: 33 lbs
Shipped from 48228 zip code
http://wwwapps.ups.com/calTimeCost?l...&WT.svl=SubNav
When I ordered the kit, the salesman told me that their quality is very high and OEM level. Napa uses their kits, so that tells you that they have good quality. Here is some random links I found out about Hi-Tech kits:
Hi-Tech home page:
http://www.hi-techengine.com/
Article on quality: http://findarticles.com/p/articles/m...16/ai_97349515
Hi-Tech contact info: http://www.enjoythedrive.com/directo...25&id=11687800
Hi-Tech used on "OverHaulin" http://www.overhaulin.com/gallery.asp?target=70
Here is there tech support to varify if this kit will work for your application
ecat@hi-techengine.com
"All of Hi-Tech products are engineered to exceed OEM specifications". What they don't make in house they source from Clevite. NO CHINESE CRAP(cheap
I'm asking $180 plus shipping from 48228. It's cheaper then the chinese rebuild kits on ebay so I figure thiss price is a very good deal.
I'll be shipping it out UPS ground the day I recieve payment.
Thanks
Aaron
Cam:
Cam Int: 0.262
Lift Exh: 0.264
Valve Int: 0.380
Lift Exh: 0.382
Lash Int: 0.00
Hot Exh: 0.01
Kit includes:
Full gasket kit
Oil Pump
Lifters
Pistons
Rings
Cam
Cam Bearings
Rockers
Block Plugs
Timing Set
Hi-Tech home page:
Thanks
Aaron
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
