FS 1992 Celica All Trac 69000 miles
Old Mar 16, 2006 | 05:23 PM
SLC Punk's Avatar
I bought it from the original owner (A middle-aged Doctor) in April 2003. The car was 100% stock. It has every available option (inc the System 10)
I have done the following repairs/maintenance:
Maintenance/repairs by me at 53,000 miles
Rebuilt Turbo with 46 trim $500
all coolant hoses (including the Hose from Hell).
Replaced Transmission oil with Redline
Replaced rear diff oil with Mobil syn
Replaced front CV boots
All oil changes done with Mobil 1 syn (5w30) every 2,500 miles
New Cap, Rotor, Wires and Spark Plugs
Spent over $3,000 at Mark Miller Toyota getting the following repairs made(@ 59,000 miles):
New OEM Head Gasket with ARP head studs
New cermetallic disc with OEM pressure plate
All oil seals replaced
New Fuel filter
replaced power steering pump (leaking)
Valve job
New timing belt
new drive belts
The reason I had all the work done at Mark Miller was because I went to have my timing belt replaced and they found that the HG had a very small external leak. I had everything else done while they had the engine/transmission out.
In June of 2005 I had the A/C repaired (valve) $400
Everything on this car works there are no leaks, no smoke and passes emissions like a new car. I am an ex-mechanic and always do the maintenance prior to the mfg recommendations.
The car is in great condition the leather on the front seats have rips in them, but that is the only flaw on this car.
I have around $13,000 in this car (including the price of the car itself).
The reason I am selling it is because I have 3 cars and the celica only gets driven once a week.
I have autocrossed it twice, and it handles great!
I will get a pic of the front seats soon..
$12,000 firm
Edit: I also installed an alarm w/keychain pager and HKS Turbo Timer, otherwise its stock..
Edit: Sept 2005. I had a shifting problem and replaced the following items:
Slave Cyl
Master Slave
Replaced rubber pressure hose with a stainless steel braided hose
Installed a longer Slave Cyl rod
Refilled system with Mobil 1 syn brake fluid.
It has been shifting great since then!
Old Mar 21, 2006 | 03:18 PM
SLC Punk's Avatar
I also listed my 4Runner for sale. Whichever car sells first, I will keep the other.
Old Mar 25, 2006 | 05:07 PM
SLC97SR5's Avatar
WOW! I can't believe you've put them both up for sale...hopefully the Celica goes first! Good luck!
Old Mar 28, 2006 | 04:05 PM
SLC Punk's Avatar
Its a hard choice, I love both cars, so that's why I listed them both, that way I don't have to make the decision.
mskalmus
May 28, 2017 07:51 AM
jon.r
Jul 11, 2015 03:34 PM
Poncho0206
Jul 10, 2015 06:21 PM
wilbertd
Jul 6, 2015 07:39 AM
