Cornfed 3" front / 2" rear lift kit (spacers) - So. Cal.
Old May 16, 2008 | 03:37 PM
rfujiwara's Avatar
Smile Cornfed 3" front / 2" rear lift kit (spacers) - So. Cal.
SOLD SOLD SOLD SOLD
I purchased these mid May 2008 and never installed them. They are still in the box and new, never installed or used. Comes with all the parts, bolts, instructions and cornfed sticker.
These cost ~$300 new but I am reselling them at a discounted price of $250 with FREE s/h. I will deduct another $10 if you pick them up locally here in So.Cal. (the OC).
PRODUCT DESCRIPTION FROM WEBSITE:
2003 - 2008, Toyota 4Runner
Burtman Industries is proud to present the Cornfed Lift kit and front leveling kits for the 2003+ 4Runner. These newly designed kits work on models with and without Toyota's new Xreas™ suspension. These are the perfect solution for a mild lift on your 4Runner. Unbeatable quality, fit, and still rides like stock.
Also works with our Spidertrax wheel spacers!
Front spacers are custom machined from 6061 aircraft grade aluminum, one of the strongest aluminum alloys to the highest tolerances. Rear spacers are made from UHMW (Ultra High Molecular Weight Polyethylene). This industrial strength plastic is an ideal alternative to Aluminum and the UHMW is very similar to the material used by car manufacturers in the OEM coilover assembly.
These spacers allow an effective, inexpensive means of getting those first few inches of lift for a larger tire, or for giving that last small amount of lift for the larger tires you may already have. Spacers are a direct fit with no cutting or welding required.
The 3" front/2" rear lift kit gives you a 3" front lift and a 2" rear lift. The 3" front spacers are machined from 6061 aluminum, and rear machined from UHMW. This kit will allow you to fit a 285/70r17 or a 285/75r16 tire/wheel combo, which is a 33" height.
This kit Will fit models with and without Xreas™ suspension.
http://www.burtmanindustries.com/zoo...up_liftkit&opt[7220]=6904242886
Old Jun 23, 2008 | 10:23 AM
HB4Runner's Avatar
Do you still have these? I'm in Orange County so I can most likely pick them up unless you already sold them.
Old Jun 24, 2008 | 09:40 AM
rfujiwara's Avatar
sold Sold Sold Sold
Jun 1, 2021 01:51 PM
lledwod
Aug 30, 2016 01:03 PM
Nickdigg
Jul 7, 2015 06:04 AM
toyoda8488
Jul 5, 2015 10:18 PM
Vargntucson
Jul 4, 2015 12:15 PM
