[Colorado] Built 1986 Turbo SR5 4Runner **SOLD**
Old May 17, 2017 | 09:15 AM
sevenphoenix's Avatar
Unfortunately the time has come to sell my '86 Turbo 4Runner. Most folks in the local Colorado crawling scene will recognize and have probably seen this rig at several of the Toyota Jamboree's we have out here.While i owned it i took it to few a jambos as well (2011 and 2012-13 i believe). The truck has always been solid and a really great/fun experience to own and crawl with but over the years i've since gotten married and had a kid and just havent had time to give her the attention she deserves for a few years now. I've also moved a few times within Colorado and outside of starting it up every few months to run through a heat cycle or two this 4Runner has become a front lawn ornament with the occasional trip around the local dirt trails just to keep it limber. Below i am going to link the build thread from the owner i purchased the truck from as well as the original sale thread where there is a wealth of information on the build-out of the truck and various parts listings on the truck.
The only changes that this truck has seen since i've owned it are the following:
-Trailgear Trunion delete kit (due to me breaking a trunion bearing at the first jamboree i crawled it at)
-added a synth winch rope
-replaced original doors with black/rhinolined manual window doors for trail purposes
-ford taurus interceptor electric fan
The truck is pretty much in the same condition as the build/sale thread and the only real wear i have put on her is the tires which are close to being baldish, the full-size spare has still never seen the road and is like new. I have maintained regular oil changes of full synthetic mobil1. I can provide pictures of the condition of the tires which in my opinion would need to be replaced (at least 3 of them) if any long term road based driving were to be in its future.
I am located in Castle Rock, CO and i am asking for a 5K FIRM price which is considerably less than what i purchased the truck for. As the listing and threads state, the disclaimer is that this vehicle DOES NOT HAVE AC OR A CATALYTIC CONVERTER so please take that into consideration if you live in a county that requires emissions for street use. My goal is to not let this amazing rig just continue to decorate the street in front of my place for years until i can finally get around to having time to embrace crawling again.
Best way to reach me for inquiries would be email at : ryan.green.co@gmail.com
Build Thread - https://www.yotatech.com/forums/f199...thread-155840/
Original Sale Thread - https://www.yotatech.com/forums/f180...r-sold-231455/
quick picture of me at the CO Toyota jamboree going up toward WhaleTail
List from threads of equipment:
The Vehicle
1986 Toyota Turbo SR5 Automatic 4Runner. The Turbo 4Runner was the top of the line option. It has the digital gauge cluster, tilt-o-meter/altimeter, power windows, power door locks, SR5 seats w/ Turbo embroidered into them, removable top, sunroof and special door panels. The odometer reads 248,631, which is not correct. The speedo cable broke earlier this year, so I am guessing that it is closer to 258,000. This 4Runner is about the cleanest example your going to find!
The Engine
LC Engineering short block bored .030 over, installed around 200k (before I bought it)
Mobil 1 Synthetic oil used since I bought it, replaced every 3000 miles
ARP Headstuds
LC Engineering adjustable cam gear
MSD 6A box, coil, super conductor spark plug wires and boot protectors
Denso Iridium spark plugs
Electric fan with Flexlite controller and in cab on/off switch
Newer radiator – around 2 years old
AEM boost controller/gauge. Running around 9.0 pounds of boost
True Flow air filter
Turbo back 3” exhaust w/ flex and turbo muffler – NO CAT
Red Top Optima
HKS Turbo Timer
Auto Meter Cobalt digital EGT Gauge
Bolted motor mounts
Gen-Right hood louvers
I removed the turbo about two years ago, the turbo checked out good (end play, no cracks, etc). I replaced the exhaust manifold gasket and all related turbo gaskets/seals.
Transmission and Transfer case
Automatic transmission with regular fluid and filter services
Auto Meter Cobalt digital transmission temp. gauge
Radesigns stand alone transmission controller. Stock/Man. Switch w/ TC lock up switch
Aux. Transmission cooler
Inchworm Automatic to gear drive T-case adapter
Gear driven transfer case with Marlin 4.7, 23 spline gear set
Modified TG style crossmember with 4xinnovations transfer case mount
TG Twin stick
.120 heavy wall rear CV driveshaft
Tires/Wheels
35x12.50x15 Goodyear MTRs w/ Kevlar, around 75% tread life
15x8 Reversed US wheels w/ 2” backspacing
Copperheadfab wheel stiffeners/protectors
Brand new spare, same wheel and tire
Front axle
85 Housing with shaved drain plug
30 Spline Longfield axle shafts and birfield
Longfield 300M Hubgears
5.29 gears w/ spool
TG Hydro assist
Marlin high steer arms w/ ARP studs, Longfield 5th stud kit and newer TG tie rod
TG truss, diff armor, shock mounts, knuckle braces and backing plate eliminator
TG U-bolts and plates
TG shock hoops with 5100 Bilstiens, and Daystar soft bumpstops
TG 3” leaf springs w/ TG 5” shackle – Front axle moved 1.5-2.0 forward of standard TG kit
Marlin HD axle seals
V6 brake calipers
2” wheel spacers
Extended breather
Rear Axle
86 IFS housing, shaved drain plug, rotated
TG diff. guard, spring hangers, shock mounts
Marlin U-bolts and TG plates
Marlin built complete 5.29 diff w/ ARB and solid crush sleeve
ARB compressor w/ tire inflator
12” Poly Performance BBCS shocks
4” TG leaf springs w/ 6” TG shackles
1” ORD zero rate add-a-leaf (spacer)
Adjustable rear brake proportioning valve
New rear shoes and install/spring kit
Extended breather
Body and Protection
Custom front bumper with winch and light mounts, tied into the front shock hoops – Heavy Duty!!!
TG sliders with extra supports and Ballistic spikes on the front
Custom rear bumper with 2” receiver, rear ¼ panel protection/sliders
Removable fold down spare tire carrier with 2” receiver
Trimmed rear fenders
Removable top and sweet 80’s graphics covered in Duplicolor bedliner
20% 3M tint all around, professionally installed
Newer windshield
Thule mounts on hardtop, Thule load bars included
Interior
New Clarion headunit with Ipod jack
Memphis Auto front speakers
Pioneer rear 6x9’s
Kicker amp and 12” sub. in box
Sirius docking station (mount, antenna and wiring). Bring your own unit (Starmate 5, etc)
Mini Cobra CB
Grant GT Steering Wheel
Cooler/Warmer center console (holds a 6 pack) 
CO2 tank holder – Tank not included
Highlift jack holder (mounted to stock roll-bar) – Jack included
AEM boost gauge
Auto Meter EGT and Trans. Temp. Gauge
Dynamat in doors, soundproofing on inside of door panels
Stock seatbelts, plus additional lap belt for driver seat
Cooler in back cargo area with custom stops to keep it from moving around
Lighting
IPF H4 Housings with PIAA Extreme white bulbs
Front corner marker lights converted to turn signals, bulbs replaced with Superbright LED’s and relay modified to flash at normal speed.
Two rock lights mounted under rock sliders with PIAA GTX bulbs
Two back up lights – one under body/one spare tire carrier
One under hood light
One cargo light
The Bad
-Exhaust does not have cat. It runs great, but I have never had an emissions test. If you have emission testing, it will need a cat installed. It is your responsibility to pass emissions, not mine.
-Speedo cable is broken and needs to be replaced. The speedo does not work. It’s an easy fix, but I have not had time.
-The AC has been removed
-Both driver and passenger side door weather seals could use replacing
Old May 20, 2017 | 09:47 AM
4Runner is sold
Racersonly
Mar 31, 2026 04:33 PM
Ruger2011
Aug 16, 2016 10:11 PM
Morganmcleroy
Diesel Swaps
Aug 14, 2016 02:14 PM
Raynyc
Aug 4, 2016 09:36 AM
