86 4runner SAS, 5.29s, 35s.... for sale
So it looks like im going to have to sell my 4runner so that i can buy a car to drive to college in.... i realy dont want to sell it but i realy dont have a choice... its sell this or take a bus to a train station everytime i wanna come home and see my girl.... :crazy: Ive just about got it finished ... all that is left is a front locker, and dual ultimate crawler..... So heres the list of what its got and what i have invested in it....
1986 Toyota 4runner Sr5 ( with the good gauge cluster)
22-re Unknown milage... with noisy valves that burns about a quart of oil in a thousand miles
3 core turbo radiator
Brand New Flowmaster Muffler with 2 1/4 " pipe from the manifold back ( has a hollow cat... i have an extra cat (brand new) that i will throw in... you will have to install it to pass smog though)
Air conditioning, Power Steering, alternator is less than a year old,
Power windows, Power Mirrors, Sunroof
5 spd w-56 tranny with stock T-case
All Pro 4in SAS with a 82 toy front axle stock aisin hubs in good working order, 5.29s and freshly rebuild knuckles ( front axle gears have less than 500 miles of use on them)
2in body lift
Marlin Crawler Highsteer
Marlin crawler steering stabilizer
Custom CV(84 CV joint) front driveshaft with marlins 8in slip splines
Extended braided steel brake lines
Marlins Vented Front Brake Rotors
New brake pads front and freshly turned drums rear with new shoes
Rear axle is toyota 8in with 5.29s, locked, and larger turbo bearings
Custom rear driveshaft with CV joint
extended Differential Breathers front and rear
Chevy Leaf springs with dual shackle setup and lift blocks that flexes like mad....( needs to limiting straps because it flexes too much)
35x13.50 Toyo Open Country MTs on 15x8 Pro Comp Rims
Smitty built fron winch bumper.
Optima Battery
Custom Mud flaps with semi quick disconnect( 2 bolts holding each on) to keep the law of your a$$
Kenwood Cd player with 2 3" Cerwin Vega 2 6" Memphis 2 6x9" Cerwin Vega speakers 400 watt amp and 10" Phonix gold Sub
Inclometer
Interior is in good condition... with small rip in drivers seat but other than that good.
Body and frame are straight... small dings in body but nothing bad....
Rear window motor is good but switch doesnt work...(i think there is a bad sensor).
axle gears, tires, and driveshafts all have less than 4000 miles on them.
:clap: I also have marlins 23 spline 4.7 gear kit cost( over $400 (brand new in box)) awaiting instalation into a dual case setup ( needs 23 spline adapter)
also have a forward shift t-case for the donnar case.
Also i have a set of used rotors and calipers for use on a rear disc brake conversion.... ( just need the kit from one the guys on this board to do it)
have two 4runner tops as well... both are in good condition.. was going to make one of them into a half top... but have run out of time and money....
only bad thing about the 4runner is that it has a salvaged title( i have carfax report on it) ( many years back it was repossed creating the salvaged title)
I have invested over $6000 in parts alone not to mention the vehicle.... so i would like to get $8000 for it. It may seem like alot but this vehicle is well worth your money... it is ready to wheel today...
Contact:
209 962-4360 ( ask for Andy)
bigfoot_87a@yahoo.com
or post on here or PM me....
2in body lift
Optima Battery
Inclometer
Contact:
not trying to ruin your parade, but ive seen quite a few toys w/ tons more over here and on pirate, for 5500 give or take a few hundred, but good luck.
bump.
WTB[PacSoWest]: Looking for Smittybilt front bumper
shisha1999
Mar 16, 2016 12:25 PM
jerusry
Oct 19, 2015 05:28 PM
