79-95 toyota trucks and 4runners
Old Feb 26, 2013 | 07:15 PM
  #81
abourgeois's Avatar
Would you happen to have a R150F transmission? Need a new one for a 1991 sr5 v6 4x4 5 speed. I am in Winnipeg and could drive down to get it.
Old Feb 27, 2013 | 07:40 AM
  #82
bandbarchery's Avatar
pm sent
Old Feb 27, 2013 | 07:58 AM
  #83
Originally Posted by BamaYota1
Need ifs Aisin hubs for 93 shipped to 35907. I could do with a couple parts if you have some that are disassembled or not complete. For each side I need the spring that mounts into the clutch cog and the flat metal washer "fowler pawl". Pm'd
Also need a front driveshaft for regular cab 22re.
PM not recieved. I do have all of this. Two lockouts and the shaft.
Old Feb 27, 2013 | 04:11 PM
  #84
CyroProxy's Avatar
Exclamation
Specifically, I'm looking for a engine/tranny wiring harness from the ecu out that will fit in a 1992 (mfg date is Dec 1991) Toyota pickup 22re 4wd 5SPD Ext Cab. My part number is "7124-5335 PP XA-3"
I have an old "7124-5335 PP XA-1" but the connectors do not fit my ECU.
If you have something that will fit a similair model with minimum modifications (Like if i have to replace the Knock sensor because the harness is the wrong size) then that would be appreciated.
The "7124-5335 PP XA-3" can NOT have any cuts/splices and if a matching ECU is available then I may want it also.
My ECU is part:
89661-35630
Old Feb 27, 2013 | 04:43 PM
  #85
My ECU is part:
89661-35630
I might have one that is unknown condition. I have one that i am keeping with the engine it is with. I would see if you can figure out the part numbers for the plastic plug housings you need. New united race tech should be able to get the plugs. Then just transfer the pins to the new plugs. Cheapest and easiest way I know of. It will require some research though.
Old Feb 27, 2013 | 06:44 PM
  #86
wzest's Avatar
Originally Posted by bandbarchery
I have been parting these trucks for years. I have around twenty parts trucks right now. I have many many parts. Text or pm me what you need. I can ship smaller stuff. 218-5five six-036one
Located: Bemidji, MN
I need new lock cylinders for a '93 4runner. 4 doors, tailgate, and ignition, preferably matched. Any availability? Thanks much for your help!
Old Feb 28, 2013 | 04:11 AM
  #87
I do not have a complete 2nd gen runner set. Sorry.
Old Mar 11, 2013 | 07:56 AM
  #88
tditoyota's Avatar
I'm looking for both of the rear side marker light assemblies for an 81 toy pickup. Thanks for any help you can give me.
Old Mar 11, 2013 | 08:07 AM
  #89
Dimedout's Avatar
I'm in need of all or as many parts as I can get from one location to do a auto to manual swap on my 88 Xtra cab. Pedal assy, trans, trans case, cross member, shifters, trim. If you would be intrested in swapping some stuff all my auto components are in great working order. Thanks.
Old Mar 11, 2013 | 07:24 PM
  #90
This would not be worth the shipping. Sorry.
Old Mar 11, 2013 | 07:26 PM
  #91
I might have them but i cannot get to my first gen trucks right now. Hopefully the three feet of snow we have will start to melt soon.
Old Mar 11, 2013 | 08:43 PM
  #92
tditoyota's Avatar
I know what you mean, I used to live in Fargo, hehe. I'll hit you up again when it gets nicer out there.
Old Mar 12, 2013 | 07:22 AM
  #93
monyman's Avatar
90 pickup interior part
I'm looking for a blue dash pad for my 1990 SR5 Pickup sent to 93291 (can be commercial if it matters). Thanks.
Old Mar 12, 2013 | 02:04 PM
  #94
SpecialScottie's Avatar
Looking for 2 wheelhubs with lockouts and spindles from a solid axle truck to 91352
Old Mar 16, 2013 | 12:50 PM
  #95
mt_goat's Avatar
Do you have a "cold spec" front windshield wiper motor?
Old Mar 16, 2013 | 06:53 PM
  #96
Hezzy's Avatar
I'm looking for a non ADD tube and the associated parts. shipped to 89021.
Thanks
Hezzy
Old Mar 17, 2013 | 08:52 AM
  #97
Rajuko's Avatar
toyota 22re lower intake manifold needed
Need lower in take manifold. I understand they all the same from 88-95
22re or 22rec engine I'm in GA
Old Mar 17, 2013 | 08:59 AM
  #98
Rajuko's Avatar
need lower intake manifold for 22re ship to 30268
Old Mar 18, 2013 | 02:46 PM
  #99
Chunk's AE's Avatar
do you have any metal mirrors?
Old Mar 21, 2013 | 05:11 PM
  #100
mussy01's Avatar
Any chance you have the heater control valve with mounting bracket from a 89-95 truck or 4runner? If so, please shoot me a price for priority mail to 80550.
Thanks
