22RE in TX - $500
22RE in TX - $500
I've got a complete 22RE that I'm selling as a longblock.
1988 Toyota 4runner.
Location is Austin, TX.
Will crate for $100. Shipping on your dime.
160-164 psi on all 4 cylinders.
Can do a leak down test on site - otherwise I'll have it out tomorrow afternoon.
Odometer shows 158k miles, but this truck was towed behind an RV - so actual miles unknown. Truck was in excellent shape and previously owned by a mechanic at one of the local dealerships.
I drove this motor daily and did a 2-3k trip this summer without a single problem, didn't need oil, doesn't smoke, I've got a recent smog inspection if you'd like to see results.
It doesn't leak a DROP of oil or water (other than the mess I just made on the top of the valve cover).. It's absolutely clean, it doesn't use any oil.. Literally you can drive it for 3k without adding anything or noticing an oil level change.
No timing chain noises or issues.. Everything looks to be OEM down to the bolts.
Come drive it, test it out, whatever...
I'm replacing it because I've got a new turbo charged 22re that I'm putting in it's place. Absolutely nothing wrong with this motor!
Are the 88 Odometers cable driven or electric?I'll take it.Drive over here and I'll help take it out and put the other in.
Seriously I'd Like to have it but not sure what the cost of shipping would be.My Dad blew the head gasket in his 4x2 and it would make a good replacement.The dingbat did'nt keep his oil changed and it checked out at 100K.And we all know what happens to the driver's side guide when you don't change that oil.Almost happened to mine but I discovered the extent of the damage when I attempted to replace a leaky front seal.Chain had almost eaten through.$300 and two weeks later (had to wait on parts to ship)I had a good as new engine.New valve cover gasket,oil pump,water pump,timing set and virgin timing cover.
are you looking for any trades, I have 4.7 crawler box, or complete 85 front axles or lots of toy parts interior and exterior. LMK
It sold.. thanks for the interest.
Wrench, I've got a new hays brute clutch and a $600 turbo manifold (turbonetics) if you're interested in that stuff.. I am looking for a crawl box and misc red interior parts.
FS[PacNorWest]: 1992 4runner - 5VZ swap - Lifted
Swim
9
Jan 4, 2016 10:47 AM
