2001 4Runner 4x4
Old Aug 1, 2015 | 11:30 AM
mussy01's Avatar
2001 4Runner 4x4
Finishing out the part-out of a 2001 4Runner SR5 4x4 AT with 78,000 miles that I purchased as a running donor for a 3.4L swap. The parts listed below are all that I have left. All prices listed are negotiable and I'm ready to make a deal on bulk buys. All prices listed are pre-shipping, which will be paid for by the buyer. All parts will be shipped from zip code 80526. I have pictures for every part on the list so please let me know if you'd like me to post or IM something specific. I will update the part list once an item is sold.
- Front driver and passenger quarter vent windows - $50/both
- Air bag sensor assembly (89170-35120) - $40
- Steering wheel air bag assembly - $50
- Engine Control Unit 4x4 AT (89666-35420) - $100
- Passenger side dash air bag - $50
- Radio Amplifier (86280-35080) - $25
- Gas filler door & cap - $15
- Dash gauge cluster trim (black) - $15
- Washer fluid pump (85330-35070) - $15
- Buzzer (89747-35010) - $10
- Antennae Relay (85914-35010) - $10
- Yaw Rate Sensor assembly (89180-35010) - $40
- Running light relay assembly (82810-04011) - $20
- Tailgate power window motor (85710-35110) - $30
- Horns (2) - $10/both
- Rear wiper motor assembly (85130-35070) - $30
- Single door lock switches (2) - $15/ea
- Hood hinges (2) - $10
- Front windshield wiper frames (2) - $10
- A/C compressor - $50
- Throttle body - $50
- Driver front window regulator motor - $30
- Driver side exterior door handles (front & rear - forrest green) - $15 both
- Front door speaker assembly (1) - $10
- OEM MAF sensor (22204-21010) - $40
- Assorted relays (90987-02012 six; 82642-35010 one; 85926-30020 one; 90987-02006 one) - $25 all
- Dash board filler plugs tan (1 large, 3 small) - $20 all
- Flasher - $10
- Traction control switch - $10
- Hazard light switch - $10
- Heater assembly (87110-35040) - $75
- AC cooling unit (448800-4620) - $75
- 4wd control computer (89533-35170) - $40
- Harness assy, towing converter (08940-35810) - $30
- Box of body harness pigtail connections (nearly complete) - $75
- Engine wiring harness (missing one ECU connector from swap) - $125
- AC condensor - $30
- Front driver side door glass - $30
- Rear driver side door glass - $30
- Sunroof glass - $50
- Front Passenger door (complete - forrest green) - $60
- Front & rear driveshafts - $60/both
- Fuel tank with pump (complete) - $60
Thanks for looking!!
Old Aug 13, 2015 | 10:51 AM
todos4runner's Avatar
Do you have pictures of the steering wheel?
Old Aug 13, 2015 | 06:41 PM
mussy01's Avatar
I do not have the steering wheel but I do have the airbag with the steering wheel pad/cover intact, if you're interested in that. Just let me know. Thx
Old Aug 13, 2015 | 06:55 PM
881stGenRunner's Avatar
in dash clock?
Old Aug 13, 2015 | 06:57 PM
also does the truck have the factory fog lights and headlight/fog light/turn signal stalk?
Old Aug 18, 2015 | 05:09 PM
mussy01's Avatar
Unfortunately i don't have either of those items left. Thx
Old Sep 1, 2015 | 10:39 PM
tinigunner11's Avatar
Well not sure on the technical name for the part I'm looking for, but there's a little rectangler body filler under the head light. I'm missing the one on the drivers side or my 4Runner. Any chance you have that and are willing to part? I can post a picture also if needed.
Old Sep 7, 2015 | 03:00 AM
sashcraft's Avatar
Front skids? Also, pic of the gas filler door. Thanks.
Old Sep 19, 2015 | 12:50 PM
mussy01's Avatar
Sorry for the late reply but I do not have this part. Thanks!
Old Sep 19, 2015 | 12:54 PM
mussy01's Avatar
I do not have the front skids but I've attached a couple pics of the fuel filler door. It is hunter green in color. There are no dents but you can see fine scratches in the pics.
Old Sep 20, 2015 | 09:32 AM
Jarhead74's Avatar
Hey,
Looking, not sure if I missed it from your list, but here is what I am looking for:
center dash vents
Sunroof assembly-specifically the copper tubes/wires that pull the window-If it worked. Mine are frozen
Intake hose-goes from airbox to intake.
Shipping would be to 29860.
Thanks.
Old Sep 26, 2015 | 03:22 PM
Citykid's Avatar
You don't have the rear end do you? The whole differential and axels.
Old Dec 13, 2016 | 02:50 PM
zmbombr's Avatar
Are you still parting this out? Could you provide an updated list of anything available?
Old Dec 13, 2016 | 08:20 PM
dropzone's Avatar
Fossilized
Thread now closed, OPPO hasn't been around for 6 monthx
MO transplant
Apr 23, 2023 11:58 AM
Colington
Mar 8, 2020 09:51 AM
mskalmus
May 28, 2017 07:51 AM
MTLroadierunner
Jul 15, 2015 12:58 PM
HRDC0R19
Jul 5, 2015 06:43 PM
