1991 Toyota Pickup Standard Cab SAS'ed
Old Apr 14, 2007 | 07:35 AM
cbabywolf02's Avatar
I am thinking about selling my 91 Pickup. Its 90% complete and only needs a few more items to be ready for rock crawling. Heres the low down on the mods/upgrades:
Engine- 22r-e bored 40 over and fully rebuilt with engnbldr master rebuild kit, engnbldr crawler cam, engnbldr fully assembled head with larger ports and new stock size valves. All new belts, hoses, plugs, wires, pcv valve, cap, rotor and fuel filter all straight from Toyota.
Tranny/t-case- Stock transmission with dual case 23 spline adaptor from Marlin Crawler, 4.7 gears in rear case, speedo extension cable, and shift boot kit from Marlin. Budbuilt Dual case adapter. All-pro offroad t-case parking brake kit.
Front end-Fully rebuilt with all new bearings and seals with Yukon 5.29s, aussie locker,solid spacer, Longfields, OEM toyota drive flanges, ARP hub and steering arm studs, Trail-gear backing plate eliminator, Trail-gear diff stud kit, Trail-gear triple drilled pinion flange, vented rotors, reman. calipers, and new pads.
Rear end-Fully rebuilt with Trail-gear rear axle service kit, Yukon 5.29s,solid spacer, Yukon spool, new drums, shoes, wheel cylinders, and hardware kit, Trail-gear diff stud kit.
Suspension-Trail-gear SAS and rear lift with 4" springs. 14" travel shocks in the front. Budbuilt rear upper and lower shock mount kits.
Interior- Cheap pioneer cd player and speakers, Cobra 18wsxII cb.
Parts not installed yet- Rear shocks, front driveshaft(trail-gear 12" long spline kit already modified for dual cases), rockstomper motor mounts, rockstomper beadlocks with mudrings and button head screws, All Pro offroad sliders and Trail-Gear slider mount kit.
I think thats everything but their could be more. This truck still needs some work to be ready. No battery, no gear oil in diffs or t-case, things of that nature.
The body is in desent shape, some rust in the cab behind the drivers seat. Its has its nomal dents and dings for a 91. The truck is on its stock 225' wheels and tires. It comes with a set of half doors and the stock birfs/axles. The body has 209,xxx miles on it, and everything else has 0 miles on it. The engine and diffs still need to be broken in. The truck is located in Sykesville,MD 21784. Im looking to get $7,000 for it obo. If your interested pm me, I can post up or e-mail pics if you want.
Old Apr 15, 2007 | 05:39 AM
Heres a pic of what the truck looks like with 33s. [IMG][/IMG]The 33s will not be sold with the truck, stock wheels and tires will be on it. You can find the rest of the pics here. <a href='http://server4.pictiger.com/album/1180/PROJECT_TRUCK/' title=''>PROJECT TRUCK</a>
Old Apr 20, 2007 | 03:22 PM
New price, $6000 obo
Old Apr 21, 2007 | 10:30 PM
Albuquerque Jim's Avatar
Interested...
Old Apr 22, 2007 | 09:39 AM
bump, $5000 takes it, I need it gone
Old Apr 22, 2007 | 07:52 PM
PM Sent
zd92655
Mar 6, 2022 12:58 PM
Aleeex_u
Jun 5, 2016 06:52 PM
5280jo
10
Jul 13, 2015 10:05 PM
PureTacoma_Tundra
PureTacoma_Tundra
Jun 29, 2015 09:45 AM
bprice0077
Jun 25, 2015 07:36 AM
