1986 4wd Pickup + Mods
UPDATE...TRUCK IS RUNNING NOW, SEE A FEW POSTS DOWN
Its an 86 Single Cab short bed. The truck is my current DD. I bought it stock from an older man less then 3 months ago. I lifted it and put 32s on it. 5 inch Tach with Shift Light. New Infinity highs, powder coated shifter. Headlight rock guards. The motor was a Toyota Reman. with 45K on it. The radiator had a leak, And evidently the previous owner overheated it, Cause 3000 miles after owning it, it blew a head gasket. The head was checked, shaved down new valve seals and guides, new Toyota head gasket, many new bolts, I powdercoated alot of stuff, ceramic coated header. New Radiator Installed, New Fuel Pump. Lots of new gaskets. K&N Filter and MUCH MORE. Got it all back together And I have a water leak somewhere around the intake manifold. Got that fixed and all back together now. All It needs is valves adjusted and timing set, and exhaust done. The exhaust dumps open header and downpipe now. I have stock exhaust and I have a high flow cat and muffler included if you want to do custom exhaust. Probably 2 hours worth of work and it would be ready to roll. Truck has a newer bed on it from an 89, some rust on the rockers and a few spots on frame have been fixed. Manual locking hubs black rims with 32X11.50 All Terrains (Less Then a Month Old)
Asking 2000 OBO OR Trade for a Good, Newer Daily Driver, 2wd Truck, or Streetbike
All PMs replied...
I will entertain ALL TRADE OFFERS...
Finished Fixing the water leak last night. Also forgot to add that EGR is blocked off so if you have emissions it could pose a problem
I could finish except for exhaust, Im am just COMPLETLY out of time and money..PM'd You my number, I get off work at 3:30
Just let me know. Its slowly getting back together and if more gets done the price might go up too. Also I have a hookup on a 6 inch suspension lift for an extra $700
UPDATE... Truck is all back together now, Oil changed and Oil Pressure guage hooked up. The truck is running now. Had a slight miss but that could be a vacuum hose or something, its only at idle when it misses. Its runs awesome though, So now all it needs is exhuast (Sounds pretty nasty with open header haha) and a few loose ends cleaned up.
Jun 1, 2021 01:51 PM
icentropy
Jul 11, 2015 07:21 AM
toyoda8488
Jul 5, 2015 10:18 PM
but ive passed it on
