will these wheels fit?
Old Mar 8, 2015 | 08:07 AM
theduck21's Avatar
I have an 85 sr5 4x4 just like Marty Mcfly and I found the right wheels but instead of the 15x8s I'd like to run the 15x10s. I've heard of guys running the 10 inch wheels but rubbing the tie rod ends. They are US model 94 steel wheels.
Old Mar 10, 2015 | 08:13 AM
93Xtra-Cab's Avatar
Depends on the size tire you plan on mounting and the backspacing of the rim. I have 15x10 rims with 4" backspacing on my 93 pickup and they don't rub my tie rods.
EDIT: Ok, I see you have an 85, which has a solid front axle. So, I can't tell you for sure if they will rub the tie rods. Again, it most likely depends on the backspacing.
BeMiceElf
Oct 10, 2015 09:40 PM
94yotaMI
Jul 21, 2015 05:47 AM
hexrain
Jul 12, 2015 01:13 PM
skoti89
Jul 6, 2015 07:45 PM
