Wheels, hub centric or not, and spacer questions.
Old Jun 1, 2014 | 10:03 PM
Pri$erulz's Avatar
I think I might have made a mistake on the wheels I bought. I have a 1981 Pickup Sr5 4wd and bought crag ar soft 8's in 15x8. The wheels are not hub centric and I bought them under the impression they did not need to be. When I had the ties balanced the shop told me they were having trouble getting the weights on inside of the front wheels because they rubbed against the tie rods.
Here are my questions. 1) Do the wheels need to be hub centric? 2) I'd like to get some spacers to fix the rubbing issue. Does anyone have any recommendations on type? I was looking at spidertrax but none of them were applicable for a 1981 4wd Pickup.
Thanks.
Old Jun 4, 2014 | 11:52 AM
osv's Avatar
osv
the truck should have come with lug centric lug nuts; they have the chamfer cut, that centers the wheel around the nut... if the wheels have the same chamfer cut, you did good.
putting 15" wheels on 4wd toyota trucks usually means wheel adapter/spacers, which are 1.25" minimum, although there are thin spacers also... how much clearance do you need, and is there any extra wheel stud length to compensate for the spacer.
'81 vs. '85, i don't know what differences there are, if any?
glowz825
Jan 25, 2022 09:28 AM
defrag4
Jul 31, 2015 10:50 AM
terminator
Jul 27, 2015 07:13 PM
PlayAwhile
Jul 20, 2015 11:36 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
