what does 16/35-16 translate to exactly?
Old Aug 2, 2008 | 08:08 PM
88Yota4runner's Avatar
ok so i have an offer to trade some 16/35-16 boggers for my 34 10.50 tsl super swampers, now im guessing its on a 16 inch rim, but is the other part saying its a 16 inch WIDE tire?? sorry that im clueless any help is greatly appreciated
Old Aug 2, 2008 | 08:17 PM
TOYOTA 1's Avatar
yes they are 16 wide... google: intercotire
Old Aug 2, 2008 | 08:22 PM
well then crap, these are for like SERIOUS offroad then? and would i even be ABLE to fit these on my 1988 4runner? @_a
Old Aug 2, 2008 | 08:25 PM
TOYOTA 1's Avatar
No not without a bunch of lift. Wide tires are harder to clear.
Old Aug 2, 2008 | 08:26 PM
well i find the interco boggers stat sheet, and for the 16/35-16 it says they are 13.75 in width
Old Aug 2, 2008 | 08:29 PM
nc994run's Avatar
From: raleigh, nc for school chapel hill, nc for home
You wouldn't have much lateral traction with the boggers (at least in muddy sidehill situations). Plus they will wear fast, but you already have Swampers
Old Aug 2, 2008 | 08:32 PM
yea but i wanted to go BIGGER and yea i know EVENTUALLY ill have to regear and everything but for now all i want is something bigger :| so will i at least be able to drive with these? Aha
Old Aug 2, 2008 | 08:37 PM
TOYOTA 1's Avatar
yes you can drive but if you turn all the way you will rip your fender OFF!
Old Aug 2, 2008 | 08:42 PM
ahahahaha im pretty sure i can clear it, even with the 34`s right now it LOOKS like i could run a 35 easy. also if it DOES turn out to be a big problem, would just adding a wheel spacer help for right now? and if so how much of a spacer should i get?
Old Aug 2, 2008 | 08:44 PM
TOYOTA 1's Avatar
wheel spacer will actually make tire rub worse.
Old Aug 2, 2008 | 08:46 PM
ahhhhhhhhhhh didnt think about that, hmm ok well would just cutting the fenders up more do the trick? i have extended shackles in the rear ALONG WITH the fenders bumped up about 3 inches, the front fenders have never been cut yet.
Old Aug 2, 2008 | 08:48 PM
TOYOTA 1's Avatar
I've had your style truck with a 3 inch body lift and 33x12.50x15 swampers on 10" wide wheels and they rubbed when i turned all the way. So I am sure them 35 boggers would rub pretty bad.
Old Aug 2, 2008 | 08:50 PM
TOYOTA 1's Avatar
It sure wouldn't hurt. Put them on and adjust from there.
i had the v6 version of a 1988 4runner before, i had 33 12.50s and they rubbed only a little bit when i turned all the way, then that truck got stolen ;( then found again 3 months later, replaced 3 spark plug wires and sold it to my best friend for 200 bucks it ran great still
Old Aug 2, 2008 | 08:52 PM
TOYOTA 1's Avatar
thats a deal
Old Aug 3, 2008 | 05:59 AM
dirtoyboy's Avatar
You know what they say about boggers.....
"You either GO or you BREAK!"
Sidherish
Aug 3, 2015 07:17 PM
spindleshanks
Jan 3, 2006 12:16 PM
