Toyota Megacruiser tire 37x12.500x17.5 6-ply
Old Feb 18, 2011 | 06:31 AM
pvlint's Avatar
Hello,
I just purchased a military Toyota mega cruiser. I need the operator’s manual and I need to know where to get the tires. The tire size is 37x12.500x17.5 6-ply and I need to know where to get them. Any information, particularly on the operator’s manual and tires, is highly appreciated.
Thanks,
John
Old Feb 18, 2011 | 05:48 PM
camo31_10.50's Avatar
never heard of this......lets see it! i'll search the net for tires
Old Feb 18, 2011 | 05:53 PM
you're going to have to go with a different size wheel....or purchase used tires
Old Feb 18, 2011 | 07:13 PM
Philbert's Avatar
Wow....this looks AWEsome!!
is THIS what you have? WHERE IN THE WORLD??????
Old Feb 18, 2011 | 07:16 PM
BoredOutnJackdUp's Avatar
Old Feb 19, 2011 | 06:17 AM
pvlint's Avatar
Here are the pictures of my megacruiser. Sorry for the small size, there is a size limit for attachments. Just tell me if you want a larger image.
File Type: bmp
Old Feb 19, 2011 | 10:43 AM
That thing is sweet!
Don't like how the boggers ride? haha
Old Feb 20, 2011 | 06:16 AM
pvlint's Avatar
Does anyone know where I can get the tires for the thing? I cannot use the run flat inserts for the bogger. I need Bridgestone Mud Dueller 671s tire size is 37x12.500x17.5 6-ply .
Old Feb 20, 2011 | 06:24 AM
xxxtreme22r's Avatar
they don't make them, it's not even a tire size option on the www.bridgestonetire.com site.
17.5" rims are very very uncommon. Most common 17.5" rim size is used on skidsteers.
Old Feb 20, 2011 | 09:06 AM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
Toyota fail! Turn in yer man-card! That's a hot rodded, resto-mod Fj45-LV.
THIS, is a Mega Cruiser!
http://www.youtube.com/watch?v=7V8sLB8swN8
Old Feb 20, 2011 | 09:15 AM
uhmm... it's got Super Swamper Boggers on it...
Old Feb 20, 2011 | 09:24 AM
tried4x2sigN don't forget the military verion as well. Much better of the two IMO.
Old Feb 22, 2011 | 09:13 PM
jared41's Avatar
What is the bolt-hole pattern?
Old Feb 25, 2011 | 10:12 PM
pvlint's Avatar
Bolt hole pattern is 6 holes, and 17.5 rims.
Old Feb 26, 2011 | 06:25 AM
pvlint's Avatar
This is my unpainted military mega cruiser LHD version.
Old Feb 26, 2011 | 06:39 AM
^^^^ that thing is sweet.
Have you tried asking local tire dealers? Or possibly a local dealership who might make 17.5" tires?
Old Feb 26, 2011 | 07:02 AM
JamesD's Avatar
4 wheel steering?? What is under the hood?
James
Old Feb 26, 2011 | 07:21 AM
pvlint's Avatar
Yes, it is four wheel steering. Did you notice the picture? It has front and rear and center difflock.
Under the hood is a 15B-FTE, diesel, turbo-charged and intercooled, 4-valves/cyl.
4 cylinders inline 4.104-Liter 4 cylinders inline 4.104-Liter
Bore and Stroke 4.25 x 4.41 (in.) 108 mm x 112 mm
volumetrique ratio 18,4 18,4
Power 150 hp @ 3400 rpm 150 hp @ 3400 rpm
Torque 280 lbs-ft @ 1800 rpm 39,0 kg-m @ 1800 rpm
Transmission 4-speed automatic O/D transmission 4-speed automatic O/D transmission
Ratios of limps speeds
1st 3.018 3.018
2nd 1.548 1.548
3rd 1.000 1.000
4th 0,765 0,765
RG 2,678 2,678
Low range 2,488 2,488
Axle ratio 3,700 3,700
Hub reduction 1,692
Old Feb 27, 2011 | 01:39 PM
JamesD's Avatar
Hub reduction? Portal type axles?!?!?!?! This thing is AWESOME! How much do they cost over there?
Old Feb 28, 2011 | 01:49 AM
pvlint's Avatar
Price is 25,000 USD. Mileage is approximately 40,000 miles only. It is with portal axle. What's your email add, I'll send you more photos of the rear wheel steering system if you want.
