tire rotation question
i know this will sound like a stupid question but is it bad to go from the left side to the right side on a tire rotation? i normaly just got front to back but, i have always heard you shouldnt go one side to the other. is that right?
Unless the tires are directional you should cross the non-drive tires and move them to the other axle. The driven tires should just move to the next axle.
Front
Directional tires you don't switch sides as they are designed to run in one direction and mounted to the rims accordingly.
Front
Front to back every 4-5 k and your good. Unless you got a soft tire like swampers do it closer, as soon as you see them begin to wear. Your tire should be smooth as you run your hand from top to bottom.
djpg2000
Nov 11, 2020 04:56 AM
coffey50
Jul 28, 2015 10:55 AM
DrZero
18
Jul 24, 2015 11:31 PM
