M/T wheels & Nitto tires
Originally posted by SteveO
I'm making a disconnect that can be operated with a single pin, AND will keep the sway bar end links from flopping around.
Where is Lee's site at???
Oh yes, now I remember seeing these. Indeed my will be based on the same concept, however, I'm using 1" OD square tubing that will slide inside a larger squre tubing. My 4Runner is weighing in over 5000lbs, unloaded. :pat: If I load the 4Runner up with camping gear and take a road trip, I wouldn't feel comfortable having so much weight being placed on the 1/8" clip. I also have the Addco sway bar, which is even stiffer than the stock bar, and will place more stress on the center pin. The hing pin I'm using is 3/8" thick, this I feel comfortable with. However, mine are based on the same idea.
#27
Nolan, I finally got the pictures!!
Check out the below pics and the links. Click on the pictures to see a larger image. These wheels are the M/T Classic Lock with a 4" backspacing and Nitto 295/75R16 tires.
This shot is looking from the front of the 4Runner towards the rear on the driver side:
Driver side of 4Runner, different angle:
From rear of vehicle, show how far the tires stick out.
And a close up shot of the M/T wheel:
http://www.hunt4steve.com/off-road/other.htm#te
Flying91
45
Apr 11, 2024 04:39 PM
Jun 1, 2021 01:51 PM
coffey50
Jul 28, 2015 10:55 AM
