Loose front driverside wheel.
Old Nov 11, 2009 | 05:05 PM
linkspast's Avatar
So I got some now wheels and tires and put them on.. everything is going well, untill I get to the last one. Well I get it tight as it will go and it still wobbles side to side... Im not to sure what to do. I doubt its safe to drive on..
Any insight to what might be the problem..
I
Old Nov 11, 2009 | 05:28 PM
habanero's Avatar
Closed end nuts and too long studs? Why one and not the rest? If you switch wheels does the same thing happen in the same place?
Yeah, don't mess up your wheels/studs driving on them loose.
Old Nov 11, 2009 | 09:16 PM
linkspast's Avatar
Tommrow I plan on switching some wheels around.. to see if that has something to do with it. It feel like the studs might be too long.. But the older wheels did not have this issue.. however, the thickness of the old wheel might be checked too.. . .
EDIT: So the thickness of the bolt holes were just not as thick as the old wheels... So Just got thicker washers easy fix.
Here they are.. and a comparison of the tread on the new and old ones..
88sasturbotoy
Jan 30, 2026 01:57 PM
andrewtexas123
Jul 23, 2015 11:22 AM
rushw
Jul 18, 2015 01:46 PM
Yotoder865
Jul 9, 2015 07:51 PM
zd92655
Jul 5, 2015 04:25 PM
