how will this look
Old Mar 28, 2009 | 10:09 AM
4runner4life93's Avatar
Exclamation how will this look
will a 10' wheel look good in a 32 11 50
Old Mar 28, 2009 | 10:13 AM
86toylet's Avatar
Banned 'cause I was 4runnerchevy also banned
WOW, I don't think a 10' wheel will fit inside that tire. I think you mean 10", and I would go with an 8" wheel. For the sake of your tire beads.
Old Mar 28, 2009 | 05:43 PM
scuba's Avatar
hahah..
Um yeah x2 what he said !!
Old Apr 3, 2009 | 12:22 PM
tj884Rdlx's Avatar
at the most you'd wanna do a 9" wide. if you're looking for that 'stick out the fender' look, don't go wider with the rim, modify the backspacing. get a 15x8 with 3.5" backspacing. but with 32s you may get some rub at stock height.
Old Apr 3, 2009 | 01:00 PM
Hayes's Avatar
Actually, a 10 rim is optimal for 11.5 and 10.5 tires. 8 or 9 inch are technically to small for a 11.50 tire. With the smaller rim, the tire will wear down faster on the middle of the tire.
Old Apr 4, 2009 | 04:59 AM
emptypockets's Avatar
I just looked up the BFG KM2 on their site and saw that in the 32x11.50R15 size, the rim range is 8 - 10", so you would be able to use those wheels. They measure section width on the recommended rim size which is 9". Other tires may have different rim recommendations, but you're in the ball park.
Old May 15, 2009 | 09:52 PM
Pariah's Avatar
my friend has 15x10 wheels in 31 10.50's and it gives the tires a really fat look.its definatley possible
