how will this look
at the most you'd wanna do a 9" wide. if you're looking for that 'stick out the fender' look, don't go wider with the rim, modify the backspacing. get a 15x8 with 3.5" backspacing. but with 32s you may get some rub at stock height.
I just looked up the BFG KM2 on their site and saw that in the 32x11.50R15 size, the rim range is 8 - 10", so you would be able to use those wheels. They measure section width on the recommended rim size which is 9". Other tires may have different rim recommendations, but you're in the ball park.
