Advantages of 17" FJ wheels on my 1998 Tacoma with stock 15" wheels?
Old Jan 29, 2012 | 08:14 PM
castafly's Avatar
I have a 1998 Tacoma with the stock aluminum 6-spoke (with two spokes close together) wheels. After about 150,000 miles, the stock aluminum wheels are a bit scratched and oxidized, and the clear coat is chipping off. I've located a stock set of black 17" steel wheels from a 2007 (I think) FJ for $50 for all four. My question is, would these wheels fit my 98 Taco, and if so, what size of tires would be closest to stock circumference? And the most important question - is there any advantage to going with 17" wheels for my 98 Taco? 17" tires seem to be a lot more expensive than the stock 31x10.5x15's. Right now the truck is completely stock, but I'd love to put an Old Man Emu 1.5" - 2" lift on it some day (if I can justify the cost for and older truck with 150,000 miles)!
Old Feb 16, 2012 | 06:36 PM
etc.'s Avatar
Buy them and sell them for a profit to help buy the tires you want in 15".
IIRC, If you happen to go with Tundra calipers, you will need a larger rim.
Old Feb 17, 2012 | 09:45 AM
Outsane's Avatar
The 17'swill be more responsive, because of having a shorter sidewall. They will also be more likely to pop a bead, and a harsher ride. Good for cars - Bad for trucks in my opinion. If you start to run larger tires like 35's it's less of an issue.
Old Feb 17, 2012 | 09:53 AM
MaK92-4RnR's Avatar
I recently bought a set of 5 17 FJ Cruiser steelies. There really wont be an issue if you're running a larger tire ( i'll be using 35s on mine ) 17s are better for road mannerisms, and what not. I'd buy them anyway, 50 bucks is a killer deal.
Flying91
45
Apr 11, 2024 04:39 PM
the1998sr5
15
Jul 14, 2020 08:35 PM
DrZero
Jul 13, 2015 09:59 AM
Yotoder865
Jul 9, 2015 07:51 PM
