32x11.5 on 1990 stock 4runner
Old Jun 17, 2016 | 08:15 AM
TheHaak's Avatar
Hey all, to start off I've been looking around for weeks trying to find some legitimate yes-or-no answers to my question and haven't found anything definite.
I'm looking at buying some BFG A/T K02's in either 31x10.5 or 32x11.5. I will be buying some 15x8 wheels with a -19mm offset at the same time. I have a stock suspension. I would rather have the 32's, naturally, but if they only fit with a body or suspension lift then I can't do it. I will get a lift eventually but after forking out the $1300+ for the wheels and tires it'll be at least a few months until I can afford a lift. Now if those 32's rub, then I will be driving for at least three months with rubbing tires and I assume that will heavily damage my lovely new tires.
The offset is roughly 3/4 of an inch. That would mean that I could run a tire that is 3/4 of an inch wider than stock and have it fit like a stock tire (correct me if I'm wrong). I assume that the extra 1/4 of an inch of width and inch of height would not cause much of an issue, but before a big purchase I need a little more than an assumption...
So does anyone know, for sure, that 32x11.5 tires will fit and not rub on a stock suspension with a -19mm offset?
Thanks for all replies, any input is greatly appreciated! That is unless you are just coming here to say "bro just get them 33's!"
Old Jun 24, 2016 | 08:43 PM
se7enine's Avatar
The lift isn't the problem but the backspacing might be. -19 seems a little low.
Old Jun 24, 2016 | 09:53 PM
TheHaak's Avatar
I got the 32's and had them put on two days ago. They fit perfect I'm glad I took the chance!
Old Jun 24, 2016 | 10:34 PM
Trents3.slow's Avatar
Did you start ANOTHER thread about your damn tires?
wolfpackfan33
Feb 15, 2016 04:47 PM
Jamie Mello
Feb 11, 2016 09:11 PM
Redrunner3g
Jan 30, 2016 10:15 AM
ClassicMike
Jan 26, 2016 11:10 PM
data
Jul 10, 2002 06:40 PM
