2008+ Sequoia Wheel Options?
I have a 2012 Sequoia Platinum bone stock. It currently has the standard 275/55r20 tires on the stock 20x8 rims. I would like to upgrade to a larger tire 305/55r20 which requires a wider rim 20x9. My question is basically how much positive or negative offset I would need to clear the fender as well as not rub the wheel well. I don't plan on lifting the vehicle as the only option would be a 2" spacer body lift due to the air suspension limitations. I wouldn't be against going to a smaller 18" rim to get a larger tire to fit. Anyone out there with a 2008+ sequoia running 305/55r20s or similar on stock suspension? Any regrets? Fitment issues? Thanks!
idealconcepts
7
Jul 13, 2012 07:14 PM
BT17R
35
Mar 23, 2008 08:37 PM
Geographeen
26
Oct 27, 2007 02:16 PM
