1st gen rims on 4th gen (4runner 4x4)
Old Sep 27, 2018 | 07:26 PM
jagoff's Avatar
I found some info that the center bore may be different by 0.1 mm between the generations...
I'm trying to put 87 rims (not purchased yet) on an 03, both 6 lug.
I was under the impression all generations of 4runner rims are interchangeable (excluding 2wd).
Are all gens interchangeable?
Thanks,
FNG
Old Sep 27, 2018 | 11:00 PM
SomedayJ's Avatar
They have different offset:
https://www.yotatech.com/forums/f116.../#post52404735
Old Sep 28, 2018 | 03:30 AM
jagoff's Avatar
Originally Posted by SomedayJ
Thanks. I do remember reading that and think it will be OK. Other than that, they will bolt on flush and tight, right?
Old Sep 28, 2018 | 05:26 AM
arlindsay1992's Avatar
I'd be worried the 15 inch rims from the first gen wouldn't fit over the brakes on the 4th gen. Offset can be fixed with spacers. Hub bore won't be an issue. All 4Runners use the same bolt pattern regardless of 4WD/2WD. The Pickups and Tacomas have different bolt patterns depending on 4WD/2WD but not the 4Runners.
Old Sep 28, 2018 | 08:06 AM
jakey poo's Avatar
This was my first concern as well. I'm very skeptical that they will fit.
Old Oct 3, 2018 | 06:41 PM
vital22re's Avatar
totally a bro
if its going on a v6 truck 90% sure they will not clear the calipers in the front.
BoomYouth
Nov 23, 2009 06:32 PM
just a 22re
Feb 12, 2009 09:11 PM
Praufet
51
Jan 17, 2007 01:57 PM
Fahrenheit 451
Jan 24, 2003 03:46 PM
HORNETS NEST
Dec 6, 2002 03:04 AM
