15x7 SR5 wheels and 35 x 12.5 tires
Okay so I know the general consensus is to run an 8 or 10 inch wide wheel for a 12.5 inch wide tire. That said, I have a set of the old stlye SR5 wheels like these:
http://www.sonoransteel.com/1990_Mini/002.JPG
I'm planning on running 35x12.5 tires. Has anyone run this combo? As far as I can tell, the only negative is that the tires will wear in the center quicker. My only reason for running these rims is that I already have them at my disposal. Oh, and would they be too far inboard, ie too much backspacing?
As far as backspacing, that will depend on what sort of lift you have. Some lifts require less backspacing than stock. If you run into that problem, add a set of wheel spacers as needed.
Flying91
45
Apr 11, 2024 04:39 PM
FS[PacNorWest]: Factory Alloy Wheels - Bay area
94whiterunner
9
Sep 22, 2015 07:28 PM
