Domestic Swaps Chevrolet, Ford, ect
LS1 Swap
Old May 11, 2013 | 04:39 PM
  #61
88ECToy's Avatar
Thanks! Hey, is West Banjo Land, GA anywhere near Potterville?
Old May 11, 2013 | 05:24 PM
  #62
kbe151's Avatar
Potterville would be about 2 hours away, maybe a little more. I am closer to Dallas GA, hence the west banjo land.
Old May 15, 2013 | 05:44 PM
  #63
Bumpin' Yota's Avatar
Looks great!! Do you think the gm AC compressor would fit in the stock location (stock on the engine) without notching the frame rail?
Old May 21, 2013 | 07:17 AM
  #64
88ECToy's Avatar
Sorry for the delayed response. Just eyeballing the compressor and brackets, I think there's a good chance that it would fit although it would be close (do I sound like a politician?). If you need a definite answer, I could lay it all out and measure.
Old Jun 7, 2013 | 05:16 AM
  #65
coryc85's Avatar
Saw you posted over in my build thread about the 4.7s and 4.88 combo. Thought I would check out your truck and holy cow you have got some skills. Your skidplate is beautiful, and of course all that work to squeeze that vette engine in there is just unbelievable.
Old Jun 7, 2013 | 06:03 AM
  #66
88ECToy's Avatar
Thanks! I love that Runner of yours. I'm looking for one for the next project.
Old Sep 15, 2013 | 12:40 PM
  #67
MrArmyAnt's Avatar
What fuel economy are you seeing? What radiator is that? The cooling system is what's keeping my project from moving forward
Old Sep 15, 2013 | 03:32 PM
  #68
88ECToy's Avatar
Honestly, I haven't touched the truck all summer. Between my mother's home being lost in a wildfire and knee surgery, I've had little time for hobbies.
The radiator is a 2 core that I picked up from Griffin, if I recall correctly. It's a hold over from the 4.3 era. I really haven't put it to the test in low and slow, so am not being a whole lot of help right now.
I did score a Viair compressor for the lockers and finished the 3rd or 4th redo of the battery box, things I can do while hobbling around on one leg...
Old Oct 14, 2013 | 09:26 AM
  #69
Ride4Fun's Avatar
Just read the entire build. Man this looks great and is great inspiration for the 5.3 swap we are getting ready to do in my son's 91 Pickup.
Old Oct 18, 2013 | 05:58 AM
  #70
88ECToy's Avatar
Thanks. Looking forward to pictures of your project. Been working on the air system and have made good progress. I tried every way possible to mount the York compressor, all to no avail. Plan B was an electric unit:
Air valve solenoids and pressure switch mounted on the forward trans cooler mount behind the cab and out of harm's way
The compressor does a good job of reaching cutout pressure. Ops check revealed a frozen solenoid valve, no big surprise considering how long this things been sitting.
Old Oct 23, 2013 | 07:01 AM
  #71
88ECToy's Avatar
More progress made, cold weather in the forecast makes for a good motivator.
Replaced the bad solenoid valve, ran the final electrical with switch installation.
Switch panels done.
I can see the light at the end this tunnel!
Old Oct 27, 2013 | 12:12 AM
  #72
rooster18's Avatar
I like the intake. How it's up near the center. Good for deep ruts and water. What is it from?
Old Oct 27, 2013 | 10:38 AM
  #73
88ECToy's Avatar
Hey Thanks! It's just pieced together from sources I found on the net. 4in. aluminum tube, rubber elbows and a K&N filter. If this whole thing really works, I might build an air box around the filter to capture cold air kinda like the old shakers.
Old Nov 13, 2013 | 05:49 PM
  #74
88ECToy's Avatar
I finally have the interior going back together to the point of installing seats. With that passenger seat bolted in, I found insufficient clearance between the ECM and the bottom of the seat cushion. Something had to give, it would be a lot easier to relocate the ECM...
I found a good spot for it forward of the shifter console, problem being not enough room for it and the radio. Radio removed, ECM installed. I wanted to hide the wiring and also wanted to redo the whole shifter console and this was the time.
I've been using a generic B&M shifter that I cobbled together that's served the purpose, but I never lost the desire for a good gate shifter.
Art Carr had one that I liked but cannot find one today. Ultimately, I'd like to have one with a slide away gate between neutral and reverse for those times when you need to quickly change course in an attempt to initiate plan B. Working on that. In the meantime, I ditched all the old shifter mounting along with the original Toyota console and replaced them with a one piece unit fabbed from stock pulled from my pile of 2024-T3, with solid rivets. I kinda like that boiler plate look.
With that out of the way, I can figure out where to put the radio. I see another metal box being made and fit between the seats.. Gettin' there...
Old Nov 13, 2013 | 05:57 PM
  #75
HighLux's Avatar
I really enjoy your work and the way you do things. The shifter bezel is sweet. You could sell those. Im first.
Old Nov 13, 2013 | 06:04 PM
  #76
88ECToy's Avatar
He He, Thanks!
Send me a sketch!!! I love doing this stuff!
Old Nov 13, 2013 | 06:09 PM
  #77
HighLux's Avatar
Originally Posted by 88ECToy
He He, Thanks!
With those rivets...looks so "aviation" looking. Copper rivets would be pimp.
My brain has already absorbed this plan. Continue on and build a console.
Think "airplane cockpit".
Old Nov 20, 2013 | 10:16 PM
  #78
Zpd426's Avatar
Awesome! I want a v8..... Just curious what hp/drivetrain you are running? Sorry if you said already, i might have skipped over it.
Old Nov 21, 2013 | 06:17 AM
  #79
88ECToy's Avatar
Thanks, Z
Long threads are kind of a pain sometimes, I get it. I'm not sure of the HP output, I read somewhere that it's in the 300 +/- range. I have no plans to go crazy with it, unlike a friend who just finished dropping an LS1 in his old Nova (that thing is SWEET). I'm running a 700R4 with a manual valve body, and the Toyota case, 4.70. I'm on the lookout for a D60/14B to round it out.
Old Dec 30, 2013 | 11:48 AM
  #80
88ECToy's Avatar
Just when I thought I had the shifter situated, I find this
I've been looking for a long time and finally have the right one.
