Diesel Swaps Diesel engines
Dmarsh4X4's OM617 swap to 1988 4Runner
Old 10-24-2012, 09:02 PM
  #101
pyrojoe22's Avatar
JKGen, I went with stainless braided lines from Summit with re-usable connectors and ran an aftermarket oil cooler. It doesn't leak, way cheaper to replace, and I haven't had a problem.
Dmarsh, I like your throttle cable set up. That's what I would have done if my cable was that long, but it's only about 10" out of the firewall.
Old 08-30-2013, 06:13 PM
  #102
tarenja's Avatar
I just came across this thread. Great work and great story. How't he project going?
I'm considering a similar project. I there any chance you might have the overall length of the OM617 also the height from the crankshaft centre to the top and bottom of the engine would be very useful.
Old 08-30-2013, 07:33 PM
  #103
dmarsh4x4's Avatar
Thanks tarenja,
The project has ben pushed to the back of the list for a while, house projects and work have moved to the top of the list. I do plan to move forward on this real soon, I have been collecting some parts and materials over the past month's and I am in the process of building a tube bender right now. I can get some dimensions next week when I am back in town, any thing else I can help with let me know.
Old 08-30-2013, 08:04 PM
  #104
tarenja's Avatar
Thanks mate. I look forward to following the rest of the project
Old 03-31-2014, 08:54 PM
  #105
ajrhodes's Avatar
Any way to get some pics of oil pan clearance and it measurements on the size if the notch?
Old 03-31-2014, 08:57 PM
  #106
ajrhodes's Avatar
And did you move the oil pick up towards the front if the engine when you added the section?
Old 04-02-2014, 06:28 PM
  #107
dmarsh4x4's Avatar
ajrhodes,
I can get some pictures next week, if I remember right the notch is about 3"
but then I also added about 1 1/4" to the depth of the pan, as for the oil pickup I rotated it 180 and added a 1 1/4" extension to match the pan
Old 04-02-2014, 09:12 PM
  #108
ajrhodes's Avatar
Ok great thanks or the info.
Old 06-12-2014, 12:24 PM
  #109
jody284's Avatar
Great Thread
I have been studying and collecting parts for this swap on a genII 4runner for 3 years and this is the best thread yet. I have a ?. If I understand correctly you moved the tranny back 4" with out lifting the body do you think if you had put in a 2" body lift could you of gotten 4.75 to 5"? Thanks in advance Jody
Old 06-16-2014, 09:18 AM
  #110
dmarsh4x4's Avatar
Jody248,
The limiting factor with moving the motor back is the fire wall, and still having the clearance to remove the valve cover, without modifiying the fire wall the most I could get is about 4", I do not think a body lift will help any, but you could take a hammer to the fire wall and massage it a bit
Old 06-16-2014, 10:54 AM
  #111
jody284's Avatar
Thanks for the reply. If you have any new pics I would love to see them.
Old 06-19-2014, 04:06 AM
  #112
darian.baker's Avatar
Dmarsh i like your thread I am doing my swap this week. Do you have any pics of your engine mounts? Have you driven the truck yet? How is the power
Old 03-29-2018, 10:05 AM
  #113
Dubjunk1e's Avatar
I was wondering if you have any prints of the parts you made. I'm a machinist and I want to do the same swap in my 87 4runner
Old 03-30-2018, 07:42 AM
  #114
dmarsh4x4's Avatar
Dubjunk1e,
I do not have any drawings, every thing was done one off, but if you search this site and over at superturbodiesel.com forum you should be able to find what you need, also check out www.doomsdaydiesel.net.
If there is any specific measurements you need let me know and I will try to get them for you.
Old 03-30-2018, 08:58 AM
  #115
Dubjunk1e's Avatar
Originally Posted by dmarsh4x4
Dubjunk1e,
cool man, I really appreciate it. You did a damn good job on your truck and I hope I do as well as you did. How' the truck these days? Any new pics to post?
Old 03-31-2018, 06:09 AM
  #116
dmarsh4x4's Avatar
Nothing new on the truck other than wheels and tires and moving it about 1100 miles east to my new location, but it is a coincidence that last week I cleaned up the truck, spent some time figuring out where I left off, ordered some parts to get going on it again, should be up and working on it in the next couple of weeks, will post up dates as I do
Old 01-20-2019, 10:29 AM
  #117
Rjz5400's Avatar
soooooooooooooooooo?
Old 01-20-2019, 10:50 AM
  #118
dmarsh4x4's Avatar
I have started fabrication of the rear mounted fuel tank, have not really done enough to post about, between my job and traveling back and forth between homes (California & Texas ) I haven't had any time to work on the 4runner recently, hopefully I will have some time starting in spring.
Old 06-23-2020, 03:48 PM
  #119
Rjz5400's Avatar
surely with the covid and all you have this thing up and running now right?
hoping to see the end ... nice work so far!!
Old 09-04-2020, 10:47 AM
  #120
dmarsh4x4's Avatar
Started rebuilding the OM617
Cutting valve seats
The following users liked this post:
SomedayJ (09-04-2020)
Quick Reply: Dmarsh4X4's OM617 swap to 1988 4Runner
