Diesel Swaps Diesel engines
Any interest in a group buy of L engines?
Old Sep 13, 2014 | 12:32 PM
moroza's Avatar
I've been itching for a diesel swap in my Yota for a long time now, and recently came to the conclusion that one of the later Toyota L engines makes the most sense for me. The last L's sold in the US were in '84. In late '89, they redesigned the head, fixing the head cracking issue, made a bunch of other updates, and produced various L engines up to 2005. I want a 3L; you may want a 2LT2, 2LTE, 5L, or put a turbo on a 3L or 5L. They're supposed to be more reliable and more fuel-efficient than the 1KZ. I drove a 98 Hiace (2LTE) loaded with heavy equipment this summer in Norway, and that was a good experience that formed part of my decision to get one.
Why I want one, in a nutshell: having been updated to be as reliable as you'd expect from Toyota, they're close enough to perfect - for my needs, anyway - that the considerable time, effort, and money saved by doing an OEM plug-n-play swap makes up for their remaining deficiencies (timing belt, IDI).
What I'm finding is that there may be a lot of money to be saved if a bunch of us go in on a bulk order of engines. This is hypothetical for now; I'm just gauging interest. So who's interested?
Old Sep 13, 2014 | 01:21 PM
Rowdydudeman's Avatar
I'd be down for a turbo 3l or 5l. my thoughts are pretty much the exact same as yours
Old Oct 4, 2014 | 07:09 PM
toastyjosh's Avatar
http://www.ebay.com/itm/TOYOTA-1993-LAND-CRUISER-PRADO-HILUX-3-0L-TURBO-DIESEL-ENGINE-MOTOR-JDM-/261554904225?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ce5e31ca1&vxp=mtr
http://www.ebay.com/itm/Toyota-Hilux-2-0L-Turbo-Diesel-Engine-AWD-Automatic-Trans-Wiring-Ecu-JDM-2LTE-2L-/181531555975?pt=Motors_Car_Truck_Parts_Accessories&hash=item2a441fb887&vxp=mtr
Old Oct 4, 2014 | 07:14 PM
toastyjosh's Avatar
info
https://www.yotatech.com/forums/f2/t...el-swap-41592/
Old Oct 21, 2014 | 06:01 PM
jb451's Avatar
I'd be interested depending on price obviously.. There is a company close to me that can get a 2LTII with trans for 2500 ish..Its between that, and OM617, or 5vz. All are about the same to get in, cost wise.
Old Dec 6, 2014 | 05:33 PM
the171's Avatar
I plan to do a 3L swap at some point. Several vendors in Australia, Malaysia, South Africa, etc offer swaps for sale. Alibaba has a few listings although $ info is vague. Anyone know about the going price for a complete mechanical injection 3L or 5L swap?
Old Dec 6, 2014 | 06:12 PM
moroza's Avatar
Having called a few junkyards in Australia, and contacted some vendors on Alibaba, pricing on engines (I looked only into 3L) seems to be about 1500-2500 each, excluding shipping.
Old Dec 6, 2014 | 06:17 PM
the171's Avatar
well thats pretty reasonable.
Old Dec 6, 2014 | 06:24 PM
moroza's Avatar
Thing is... if you contact a used parts vendor in the USA for, say, a 22RE, they'll quote you what, upwards of 1k? But go to a Picknpull and it's a third of that. I would think that a self-service yard in Thailand or something would also be a lot cheaper than the best price I found there.
My own interest in the buy has paused, due to disruptions in my workshop rental situation. It'll resume in the spring, but if there's interest I can start making inquiries for... 5 engines? 10? Who else would want in if we could get, say, 1500 shipped for a 2LT, 2LTE, or 3L (5L would be more because they're rarer)?
Old Dec 13, 2014 | 07:31 PM
jb451's Avatar
Where are you located moroza? I think most people are going to have to factor in shipping once it gets to our side of the world, unless you've got a semi, vacation time, and money in your pocket to burn lol
Old Dec 13, 2014 | 07:36 PM
moroza's Avatar
A semi? Naw. An engine weighs less than 500# with all the fixins, so even a stock Yota can carry two in the back.
I'm not far from the port of Oakland.
Old Dec 14, 2014 | 06:24 AM
blake.nemitz's Avatar
have any of you guys though about using a Kubota? they can be had in many variations fom 1 to 5.0 liters of displacement, direct or indirect injection 2 and 4 valve heads, mechanical or electronic injection.
Over at 4btswaps.com the kubota2.2l and 2.4l are very popular for jeeps and ranger swaps, a few build even run compound turbos. A kubota is built way more robust than a stock yota diesel and can be beat and flogged all day long. look at the crank design and youll see why.
If it were me I would use a Kubota v2405 DIT. its a 2.4 liter 4 valve head, and direct injection. the pump is easily adjustable like many kubotas its similar in funtion to a p pump as it has a seperate cam to run the injection pump plungers inline that bolts in to the block and isnt a VE style pump.timing is adjusted with shims and fuel with rack travel screws. a gov. spring mod is neccecarty to make it more road friendly to get full fueling until rev limiter. with an atmospheric turbo feeding a smaller one these little engines are making mid 30's mpg and more than enough power to blow the doors off a 2lte. not to mention it wouldnt cost as much if you can make some parts and find a decent kubota. I would swap a mechanical 1kz over a 2lte but being in the startes for a small powerful diesel kubota or a 2.3 cummins a series or b3.3 series are an easier option to source. not to mention all of the perkins diesel variations out there.
Old Dec 14, 2014 | 11:02 AM
moroza's Avatar
Good stuff, but the purpose of using an L is for it to be plug-n-play. A Kubota or Cummins is anything but.
The problem most cross-breed swaps on a 1st gen seem to have is clearing the oilpan. We have less longitudinal distance than most vehicles between the axle and firewall. One solution is a lift; another is axle relocation; a third is custom oilpan. An L makes the most sense for people who, like me, don't want to do any of those things.
I've used and worked on some Perkins engines and have a positive impression of them, but I'm not aware of any 4-cylinder turbo Perkins, nor of any more powerful NA ones. The 4.135 found in old Mazdas and Rangers is a lovely little mill, but IMO 65hp is not enough for even a stock 4wd Toyota.
Old Jan 14, 2015 | 03:49 PM
jb451's Avatar
lol, i was referring to you driving around the country dropping all the imported engines off at everyone's doorsteps…
Any updates on this? Got a line on either a 2L or 2LII (he doesn't know which) from a member here, was thinking about picking it up if shipping isn't outrageous.
Old Jan 15, 2015 | 04:57 PM
moroza's Avatar
I'm halfway through a complicated house move and haven't been pursuing this much. That should be done in a month or two.
A non-turbo 2L pushing your 4Runner around? Well, it'll make your Camaro seem that much faster I guess.
Old Jan 15, 2015 | 06:34 PM
jb451's Avatar
Yeah, i was only gonna get it if i could get it cheap, and i mean like CHEAP. I think those things only put out like 60 ish hp? That would be interesting for sure.
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
icentropy
Sep 16, 2020 02:47 PM
crashburnoveride
Aug 28, 2015 09:20 PM
Yota.Jay
Jul 23, 2015 08:08 PM
shar
Jul 9, 2015 12:38 PM
