All Other Toyota Swaps I4, I6, Lexus V8
93 V6 into 90 4cyl.4Runner
Old Jul 22, 2009 | 11:05 PM
MAS Automotive's Avatar
Need some input everyone. Have a customer that brought a V6 engine/ecu/harness/AUTO. trans and transfer case set-up out of a '93 4Runner 4x4 to my shop.
He currently has '90 4Runner 4x4, 4 Cyl with a MANUAL trans.
He wants to stay with manual transmission.
Can this swap be done without to much regret?
Old Jul 22, 2009 | 11:39 PM
Tubbyfatty's Avatar
I think if you go from a 22re to the 3vze you need different driveshafts.
As for the ECU, im sure it can be fooled to think its in neutral.
Old Jul 23, 2009 | 12:10 PM
fireman1559's Avatar
im thinkin the manaual trans will bolt up to the 3.0 i cant see why it wouldnt want to. wait why did he bring you all of that stuff all he needs is the motor ecu and harness. it sounds like he has brought u more stuff than what u need to do the swap with u might need a shorter drive shaft for the v6 but other than that. i might be way wrong but thats what im seein
Old Jul 23, 2009 | 07:14 PM
Adam F's Avatar
Manual trans from the 4cy WILL NOT bolt up to the V6
You will need a R150 trans and transfer case that came from a V6
You will need to fabricate new motor mounts
You will need a manual trans ECU and harness
You will need a bigger radiator
The swap is not worth it. The older 3vze V6 arent the greatest of engines.
You would be MUCH better off swapping in a 3.4L 5vze. There is an entire forum dedicated to this swap right here on yotatech.
Old Jul 24, 2009 | 08:11 AM
toyminator2000's Avatar
I think you need to tell the customer they are crazy. If they want to spend the money for you to do a custom engine install they might as well put in the much much better 3.4 from the 96 and up trucks/4Runners.
