what to do with my little old 3.slo
Old Mar 20, 2011 | 06:44 PM
  #41
Kody B.'s Avatar
link
here is the link http://s1195.photobucket.com/albums/aa388/The90toyota/?action=view&current=yoter2.jpg
Old Mar 20, 2011 | 07:43 PM
  #42
dntsdad's Avatar
Originally Posted by Kody B.
For $75 I would buy it. If you decide not to swap, you could always sell it for that. I know someone that would buy it right now for that just for those plugs to the ecm and scrap the rest.
Do you know exactly what it came from. Year and model is VERY important!!!! On that blue tag in the picture there is a part number. What is it?
Old Mar 21, 2011 | 06:32 AM
  #43
mt_goat's Avatar
Copy and paste the IMG code line:
Old Mar 22, 2011 | 06:47 AM
  #44
Kody B.'s Avatar
Alrighty guys this is prolly a stupid question but I need to know if an ecm from a 2wheel drive truck will work with a 4wheel drive?
Old Mar 23, 2011 | 08:21 PM
  #45
Kody B.'s Avatar
well i have the chance to buy an ecm from a 97 t100 but will that work with the wiring harness i just bought? wiring harness is from a 97 t100
Old Mar 23, 2011 | 09:36 PM
  #46
dntsdad's Avatar
Personally I would pass on the T100 ECM. They are a it different that the Runner motors I believe.
Runners will not have an EGR and some Tacomas and t100's do which will cause issues with the ECM looking for it.
Did you ever get the part number for the harness on the blue label.?? You really need to know what that harness is from before you go ANY further. That will dictate a lot.
ECM's are very easy to find and not all that expensive ($75-100) for a 96-97 manual Runner ECM. The harnesses are the hard thing to find, so if you have a winner there in that harness you need to know. get the part number and post it up.
You are doing a good job Cody for a kid or anyone else. Keep at it!
Oh and PS..........2x4 vs. 4x4 for the ECM won't matter for what you are doing
Old Mar 24, 2011 | 04:07 AM
  #47
Kody B.'s Avatar
Ok thank you dntsdad, I think this is what you are looking for...JT3HN86R2V0060172
Old Mar 24, 2011 | 04:37 PM
  #48
dntsdad's Avatar
That looks like a vin #. Maybe a deler can tell exactly that number lines up with as far as a vehicle. My electronic parts cat. only list 96-02 Runner/Tacoma......duh??
there should be a part # on it that looks like xxxxx-xxxxx (a ten digit number)
Old Mar 24, 2011 | 06:15 PM
  #49
Kody B.'s Avatar
there is a #that goes 82121-3D420-1 but that is a digit too many? so i dont know if that is the # you are looking for because i dont know where the appropriate place to look is but i found it on this spot...
http://s1195.photobucket.com/albums/...019192576...so maybe that is it? Thank you for your help
Old Mar 26, 2011 | 12:35 PM
  #50
Kody B.'s Avatar
well the good news is I searched that number on google and it appears that it is the right wiring harness for the job...next thing to do is to find an ecm...also my uncle did pull the 4runner out of the mud and snow so i can start trying to get it ready to fire up and do a compression test on...
Old Mar 26, 2011 | 12:52 PM
  #51
Kody B.'s Avatar
Im dumb for not having noticed this before but I was going over the ORS instructions and realized that in mid 97 that they changed the tps wiring from 4 to 3 prong since this 4runner is a 96 and harness is a 97 that is going to be a problem...can I just switch ends? or is the wiring harness even have the tps connected to it which i am guessing it does because i would expect ecm would run that...
Old Mar 26, 2011 | 06:41 PM
  #52
dntsdad's Avatar
Lovin it!!! How old are you again? I think that I have some Vans that are older than you!! You obviously have been doing your research and are asking some good questions, which is MUCH more that I can say for many guys that ask ridiculous question that just prove that they have read nothing and want a step by step manual like putting together a swing set or something.
Anyway, I am about 99% sure that in 96-97 use basically everything the same as far as monitoring sensors. I recently matched all of my components to a guy I know that has a 96 Runner and every part number was the exact same.
In short, you will be fine. Now you just need a 97 manual ECM. Part number is 89661-3d140 Car-part.com is a good resource for ECm's search computer box-engine control. They go from $50 and up. I paid $50 plus $10 to ship for mine.
MODS!!!!!!!!!!!Can we get this thread moved into the 3.4 swap forum and get this kid some more eyeball that can help as he proceeds forward Please??
Old Mar 26, 2011 | 10:18 PM
  #53
Kody B.'s Avatar
Dntsdad, thank you...Im 16, and as nice as it might be to have some people looking at this so far all the questions I have asked you have been providing an answer for...so thank you once again and I will definitely check in on the ecm thank you for the parts number...also update I went out to my uncles tonight and got the tumblers broken out but I think the starter is starting to go out which leads me to my next question I may have read about this already but i can not remember so will my starter from my truck fit on that engine it looks like it should but im not for sure but it would be nice if it did because I just put that one on at the beginning of the summer so I would like it if I would not have to buy another one...
Old Mar 26, 2011 | 10:59 PM
  #54
dntsdad's Avatar
It will fit
Old Mar 26, 2011 | 11:07 PM
  #55
Kody B.'s Avatar
that is great news!!!
Old Mar 27, 2011 | 07:51 PM
  #56
Kody B.'s Avatar
well the bad news is that I didnt get out there today to work on it and try to get it running the good news is I lined up a guy to do a compression test on it once I get it going
Old Mar 28, 2011 | 02:08 PM
  #57
Kody B.'s Avatar
So I have officially seen the stupidest spark plug placement ever what's the easiest way to remove them? Will upload pictures later
_
Old Mar 28, 2011 | 07:54 PM
  #58
Kody B.'s Avatar
here are the pictures of my donor...
Old Mar 29, 2011 | 03:30 AM
  #59
mt_goat's Avatar
_
Just need a spark plug socket and a long extension.
Old Mar 29, 2011 | 06:13 AM
  #60
Kody B.'s Avatar
Lol...the problem I have is they won't come out along with the socket so I need somethin to grab them with I think I know what I am going to use pull them out but when I was doing this I was out at my uncles and I didn't have much for tool supply lol
