Tach mod with pics help
Old Jan 17, 2016 | 06:25 PM
Smaay's Avatar
I have been reading on this Tach mod. Im upgrading from a 3.0 to 3.4, why should i need to change?
when i installed a V6 in my celica i just used the camry tach. same what MR2 guys do.
but since im going V6 to V6, why?
and all the threads i searched have no pictures. all dead links.
Old Jan 18, 2016 | 06:07 AM
screamer76's Avatar
Can't tell you the why, other than the signal is different and your tach will get fried if you don't do it. As far as pictures....
https://www.yotatech.com/forums/f131...ach-mod-85960/
https://www.google.com/search?q=3.4+...1DJCah0gjlM%3A
Old Jan 18, 2016 | 08:16 AM
vasinvictor's Avatar
It has to do with the difference in voltage. The resistor make the signal a usable on to the 3.4 ECU. Read enough swap threads and you'll see it necessary for the tach to work. Don't mess with what works!
My guess is that in your previous swap, you either didn't change the ECU or the ECU used the same signal as the cluster was outputting.
Old Jan 18, 2016 | 09:35 AM
SacRunner's Avatar
From my 91 4Runner:
Unmodified tach:
Modified tach (look at the blue resistor added at the bottom center of the tach):
EDIT: It's a 10K ohm resistor.
Old Jan 23, 2016 | 01:49 PM
Smaay's Avatar
^^^^ once again, you came through. Thanks so much.
Old Jun 23, 2019 | 01:35 PM
Ride4Fun's Avatar
Thanks for the pictures, I did this about 10 years ago but couldn't remember exactly where to put the resistor.
