Swapped 1999 5vz into 98 4 runner
Old Mar 23, 2021 | 07:02 AM
Daniel b's Avatar
Just finished a 1999 5vz into 1998 4 runner same eng. Same trans WON'T start I'm stumped Daniel B
Old Mar 23, 2021 | 08:21 AM
MaK92-4RnR's Avatar
Lol alright.
Go back and double check your work. What was wrong with the original motor?
Old Mar 23, 2021 | 02:54 PM
Daniel b's Avatar
Just worn out, started knocking
Old engine was knocking bad good block etc.. if someone needs one, close to Springfield mo.
Old Mar 24, 2021 | 03:08 AM
rattlewagon's Avatar
What have you checked already? does it turn over? run then die? any check engine codes? We cant see what youve done or know what its doing if you dont tell us.
Old Mar 24, 2021 | 08:37 AM
Mk_98's Avatar
so couple mistakes I've run into when doing this
1)Make sure the torque converter clicks 3 times into the input shaft or it will not engage.
2)Make sure you did not break the wiring harness to the transmission, the plastic clip usually doesn't hold up.
3) Check the starter plugs you have 2
4) Just check over every plug make sure the used 99 engine had been serviced and is in time.
Didn't give us much information so these are just the 4 common things I've run into when replacing engine/transmissions
Old Mar 26, 2021 | 01:09 PM
irab88's Avatar
Mine didn't start. Turns out I forgot to attach the small starter wire.
Does it have gas?
hogfan69
Nov 17, 2014 07:51 PM
kent
Arizona
10
Nov 22, 2007 11:02 PM
99lspwr
Aug 23, 2006 09:46 AM
MY024runner
7
Mar 16, 2003 08:17 PM
