Power steering lines?
Hey guys, just wondering what lines and how you ran them from the passenger side (pump/res) to the driver side (steering box) My 4 runner (91) had the 3.0 taken out when I got it so there were no lines, what ones are you using? Pics of how you routed them would be awesome too. Thanks!
I pieced together the 3.4 from the pump to the stock 3.0 line to the box. Welded in the middle at the hard line.
Easier to use this. Just put one on yesterday to replace my setup from the initial swap.
Scroll to the 4th from the bottom.
http://www.trail-gear.com/tacoma
I just got a set of factory 3.0 lines from a junkyard locally. it was a NON a.b.s 4runner or you could use the lines from a v6 truck also. they were 15 bucks pulled. my steering box has been moved quite a bit so i had to manipulate them a little but they worked great for the most part.
terminator
Jul 27, 2015 07:13 PM
jon.r
Jul 11, 2015 03:34 PM
